6 members (rfs56trk, TrknGMC, Gray_Ghost, Wally / Montana, walter74, 1 invisible), 75 guests, and 4 robots.
Topics128,056
Posts1,055,803
#510118 02/25/2009 3:46 AM
Have heard about testing/turning speedo with a drill. Anyone done that? Use the cable or what? Am thinking about refacing both speedo and gauge cluster, plus a new needle. Any thoughts/ideas/experiences? Thanks, this forum is the best.
If you got a nice drill you can hook the cable to it and see if it will work.
Apprentice
Apprentice
Actually you can spin it with your hand to see if the needle moves. Hook a drill to the cable and spin it slowly to see if the odometer works. I've done it recently.
dons 48 chevy #511253 02/28/2009 12:13 AM
I whittled down one of those short pencils on the end to fit the back of the speedometer. Then I chucked the other end in my drill. I thought if something went wrong the pencil would strip out before I did to much damage.
neilroy #512055 03/02/2009 2:50 AM
Can be done, make sure it is a variable speed drill! If you just want to see if it works, spin it by hand.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
Moderated by  ndkid275, Phak1
