| | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 96 Shop Shark | | Shop Shark Joined: May 2005 Posts: 96 | Hi, on the 1946
What is a good way to paint the recessed letters on the grille of a 1946 chevy, what is the trick ?
All the best,
Jan | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Take it to a pinstriper guy. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I thought some vendors carried a decal for that??? of maybe it was just the hood emblem? Marty is right. Don't get frustrated over it. Take it someone and let them work with it. | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | You will need: A good brush or two, good paint, a good work table, good light, a steady hand, a good eye, time and patience.
If you're missing any of the above, I agree with the other guys to take it to a pin-striper. Probably wouldn't cost much.
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | One-shot Enamel, Mack Brush. Good to go. Stuff like that is fun. But if you're going crazy, try and find a sign painter. Your local paint store, well the one that sells One-shot will know who to contact. But if you can buy the decal, that will really speed things up.
| | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Many of the companies sell the decal you need, or take it to the pinstripper as suggested. Cecil.......... | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Use lacquer. spray so the letters are painted, let it dry completely and then take a cotton rag, wet it with lacquer thinner and carefully wash off the overspray. That's how I did THIS. Ignore the gasket, this is not final assembly. You can also use enamel but you have to wash off the overspray before the paint sits too long. | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | I've used both lacquer and enamel, by brush and spray can, with and without extensive masking. However, I usually don't wait until the paint is completely dry, even with lacquer. Also, when cleaning off excess paint at the edges, I always use a paper towel that has been folded numerous times and dipped in a small amount of thinner so it gives a stiff surface with less chance of coming in contact with the recessed area. When you get old, your hands tend to shake a little.  With a little patience, you'll have a perfect job. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | As others have said, see if the vendors have a vinyl decal kit. Then, use the cut-out or background part of the decal as the pattern, mask around the areas and then spray paint. I did this with old hub caps for my '51, and after getting the hang of it (don't pull the masking and pattern before the paint is thoroughly dry) it looked great. Not much skill required. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | That's actually a very good idea. Those vinyl things have a way of unsticking themselves. | | | | | Joined: Feb 2009 Posts: 14 Apprentice | | Apprentice Joined: Feb 2009 Posts: 14 | The company called "Chevys of the 40's Store sell decals for this. I'm trying to decide which way is the best for my own 46.Paint will be more costly but it may last longer. The decals are inexpensive. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Paint will be more costly | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I painted the raised GMC lettering on my axle housing. It took a lot of time to get the desired result, but I used the super small rolls of detail tape at about 1/16" - 1/8" thickness to bend around all the tough spots. Then hit those areas with some newspaper and masking tape and give a good quick spray. Heres the pic of it.The photo doesnt do it justice (bad clarity and glare) and this pic was before I touched up the rest of the housing. It definately takes time and patience. Jeff | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | |
