6 members (sron48, Charles in CA, Gray_Ghost, 66flea, Wally / Montana, dt235sd), 72 guests, and 1 robot.
Topics128,050
Posts1,055,757
#508371 02/21/2009 2:49 AM
Need help with exact location of the accessory tail lights offered simalar to the 39 chevy style.
Sully
For a 1948 Suburban? Here's the template.
tim...to make it work don't you have to "mirror" it for "the other side"?
I've stuck this template up to my panel and while I "know" where it goes I'm just not that darn sure...am I making sense? ...or is it I just hate to put a punch mark in the new paint smile
Alvin,
Here is a drawing with the template in place. Yes, you would turn the template over when marking the other side.
I understand the fear associated with drilling these holes. Mark the holes with chalk and then place the lamps holders over the holes (to assure yourself that the location is correct).
Tim
Tim, what a swell guy you are!! That makes it easy and also calms my nerves....just a little. I printed it out so I won't loose it! I'll have to make a pad out of some material.
** I bought a set of the Chrome bullet lights from the guy in Oregon. Didn't you buy a set?? or was it Weeds or Gmoniz. You know, half price of what most vendors want...and they are good.
Sully and Alvin, I was lucky enough to find a pair of original bullets at a swap meet here in Wisconsin. I used Tim's template to drill the holes and they fit perfectly. I can't vouch for the stud location on the reproductions but I would check if there are any differences between the stud locations on the template and the repro before i did any drilling. Pics of mine on Picasa. Weeds
Weeds #508683 02/21/2009 9:58 PM
I put a set of the repros on my suburban,,the template matched up perfect.
Wow: Burb heads, thank you!The install and fab work is easy,i could not recall seeing any here in the south with them and was'nt sure of the height.
Sully
