| | | Forums66 Topics128,052 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | Hey All, Looking to get the 'bolt out of the garage this spring! Can anybody recommend a "sloshing sealer", or offer any tips for cleaning/sealing my gas tank? A forum search yielded no results. Here's one product I found: http://www.theshopproducts.com/products_gastank-sealer.htmlThanks! -tyler | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Persnally I dont like them. If it starts comeing loose you will be in a worse mess. If a new tank is readily available for your model I think that is the way to go. If its minor rust you can put a in line filter under the tank & check it often at first. If its serious rust & there is no replacement available use the sealer but follow directions to the T & dont rush it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | Thanks, WBR. A second, more thorough search of the forums turned up many discussions of this topic. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I have used a similar product in the tank of my '39, unfortunately it was 30 yrs ago and I dont remember the name of it , however , during the 6 yrs that I used it as my work truck, there was never another problem with the fuel delivery or storage.
ps, similar product is used in aircraft wing tanks as sealer, no problems there either. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I used a product like that on my first truck, a 67 datsun. My Dad and I sealed the gas tank, worrying about rust... The truck sat for a year while we rebuilt the enigne, and yes there was gas in the tank- not so good. The sealer began lifting and coming off in sheets. We eventually cut a big hole in the top of the tank, and cleaned it out, and welded it shut. It was safely done though.
That being said, the fault must have been ours, as airplane guys and gals use it all the time. Frankly if its used in an aircraft, it probably is good enough for me. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Heres a link to a few posts when I did mine. Burning the tank out with acid.Sealing the tank.Im very happy with how it came out. Hasnt been a problem yet and I doubt it will be. I spent an awful lot of time prepping it which I think is the key to applying the sealer correctly and the main reason why other sealers fail. Always remember safety if you decide on the acid route! Jeff | | |
