0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Anybody use any of the gauge decals that are offered by Jim Carter and some other parts places to cover the gauge faces and speedometer? My gauges work, but have faded and must have been replaced at different eras, as the fading is not consistent. I am jut wondering about the look and quality. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Ive used them on 2 different gauge/speedo sets and they look really good. Just make sure the old gauge face is clean and free of bumps,as theyll show up in the new sticker. Spray the faces with lightly soapy water and position the sticker where youre happy with it and then press the excess water out,and leave them to dry. Once its all back in the dash,it looks like new! | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They are really easy to use but Marty is right about the bumps every little thing will show. Take your time and work carefully and it is a fun little project. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | had the decals on my 37 for 9 years and counting. Still look good and I also put them on my panel.
AGAIN, make sure the face is clean. The least tiny particle will show a little "bump" as stated above. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Ditto on being clean and using a little water to allow some install movement. I used rubbing alcohol to clean after I lightly sanded. Some pictures here. Have fun and good luck Dan | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | yes makes them look new very cost effective | | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | I bought a set, but have not put them on yet. I have seen Achipmunk's and they look really good. I am a little picky over the 'safety first' missing under the 55mph like the stock dash has (1937). I am hoping to figure out how to get it on the decal before I install them..picky I know... | | |
