3 members (FishinToms53, joe apple, Hotrod Lincoln), 81 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
Looking for an aluminum radiator for a 50 3100 with a 383 sb chevy and automatic. May add air later. Any recommendations for quality,fit,manufacturer and part numbers?
call Classic Industries 8008541280. They have them for $550 last year. Maybe cheaper now. Better plan on a fan shroud and overflow tank w/180 deg thermostat.
Check the radiators out made by PRC. I bought one last year and it was well made and was a little over $400. Check them out at Rutter's rod shop.
mike
BeCool Radiators Very good product ask any street rodder. Be sure and put a good electric fan with it. The best as far as I am concerned Spal a very good product made in Italy! It has lots of rated CFM's! Biggest in the industry for its size. I also suggest to run a separate Tranny Cooler less hassels on cooling the tranny. Just remembered use a true street Radiator and not a racing type. Get the one inch tube model and if you use a down flow make sure it goes up and down for twice the cooling effect meaning the tubes are inter conected fron top to bottom to exit. This will cost a little extra but worth the extra cash.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Hit your local radiator shop. Preferably one that does race radiators. I got a custom rad made up for about $250 that looks almost the same as the original harrison (except for core). I also got a custom aluminum shroud being made up. I am running a manual, however a bottom tank cooler for your automatic shouldnt be much more.
For street driving, I recommend a bottom tank cooler. For severe towing and racing, a separate cooler is recommended.
If you are looking for an electric fan, ONLY use SPAL or Tri-Pac. everything else are simply sub-par. I do not have any ties to either company, however these are the only fans that actually flow the air they claim base on actual NIST traceable testing.
I have NOT installed mine yet but I bought a new radiator from JimCarter which is a 4 row with bottom tranny cooler. I think it is really a Desert Cooler (they have to get them from someone) and it will bolt right in. With the stovebolt discount and actual shipping charges I think it would save money and do the job unless your dead set to buy an aluminum.
Check out Ebay. I saw some the other day for $219.
Robert C.
I'm a Genius in the making.
1950 3600
