| | | Forums66 Topics128,080 Posts1,056,315 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 49 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 49 | Looking for an aluminum radiator for a 50 3100 with a 383 sb chevy and automatic. May add air later. Any recommendations for quality,fit,manufacturer and part numbers? Thanks | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | call Classic Industries 8008541280. They have them for $550 last year. Maybe cheaper now. Better plan on a fan shroud and overflow tank w/180 deg thermostat. | | | | | Joined: Apr 2005 Posts: 35 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 35 | Check the radiators out made by PRC. I bought one last year and it was well made and was a little over $400. Check them out at Rutter's rod shop.
mike | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | BeCool Radiators Very good product ask any street rodder. Be sure and put a good electric fan with it. The best as far as I am concerned Spal a very good product made in Italy! It has lots of rated CFM's! Biggest in the industry for its size. I also suggest to run a separate Tranny Cooler less hassels on cooling the tranny. Just remembered use a true street Radiator and not a racing type. Get the one inch tube model and if you use a down flow make sure it goes up and down for twice the cooling effect meaning the tubes are inter conected fron top to bottom to exit. This will cost a little extra but worth the extra cash. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Hit your local radiator shop. Preferably one that does race radiators. I got a custom rad made up for about $250 that looks almost the same as the original harrison (except for core). I also got a custom aluminum shroud being made up. I am running a manual, however a bottom tank cooler for your automatic shouldnt be much more.
For street driving, I recommend a bottom tank cooler. For severe towing and racing, a separate cooler is recommended.
If you are looking for an electric fan, ONLY use SPAL or Tri-Pac. everything else are simply sub-par. I do not have any ties to either company, however these are the only fans that actually flow the air they claim base on actual NIST traceable testing.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have NOT installed mine yet but I bought a new radiator from JimCarter which is a 4 row with bottom tranny cooler. I think it is really a Desert Cooler (they have to get them from someone) and it will bolt right in. With the stovebolt discount and actual shipping charges I think it would save money and do the job unless your dead set to buy an aluminum. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Check out Ebay. I saw some the other day for $219.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
