5 members (Youngin' Tut 59, klhansen, DadsFirstPickup, BarryP, 1 invisible), 73 guests, and 2 robots.
Topics128,139
Posts1,056,758
Members48,454
Hey there guys...just another newby here from Idaho with a '58 big window. Hope someone can help me with this situation. I just bought a '69 Camero rear end to put into my truck and will be installing a TH400. What is the best solution for a driveline? Will the original Camero driveline fit right into the TH400? Lil' help here in Idaho. Tired of spending the BIG bucks at the rod shop since this is my third project. Thanks, Steve from Idaho
Hi bigdog, I too have a 58' but its not a big window =( but I do have a piece of advice for you. even if the splines on the drive shaft fit the rear end and trans the length and drive angles may be askew. so what i would do is measure the distance between the tail comb (output shaft tip) of the transmission and and the yoke of the differential (after installation of course). take this measurement carefully and with info on your diff type and size along with trans info (type) and go to your local diff/driveline shop and they will either fabricate one for you or customize yours. if you are lucky enough the original driveline will fit but those chances are very slim. if at all possible let them make the measurement each shop has dissimilar procedures. However on the other hand if the yoke splines on the drive shaft fit splines on the trans then all you need to worry about is length. be careful if measuring the driveline itself because some shops measure from weld to weld and others from the center of the u-joint bearing caps at each end. hope this helps.
Shovel all the coal in, gotta keep it rollin! .
1958 Chevrolet Apache "32"
Former Workshop Owner
Hello bigdog58,
Torque Wrench is right on, the chances are very slim that your drive shaft will work as is. You won't know for sure, until you get the rear end mounted and give it a try. Your local drive shaft shop should tell you what measurements are needed.
Welcome to the Stovebolt
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Hello, Steve... I can't help you with your driveline question but I'd like to offer up a big and hearty Welcome to the 'bolt cool
You might want to check out the Engine and Driveline Forum & also maybe try a search & see what you come up with. Here is a link to a Tech Tip for getting the best results when doing a search (it is from the IT Short Bus Forum) wink
You're in a good place with good folks, make yourself at home.
Sabrina
'54 3100
Welcome to the Bolt,Steve
bigdogs are welcome here to smile a big hooooowdy and a big welcome to the best dang truck site there is. Lots of info, lots of nice folks....young and old and in between. Make your self at home.
2 Offline
Welcome to the Stovebolt, Steve. wave
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one.
-Ralph Waldo Emerson-
Hey Steve. Wecome to the Bolt.
Hey Bigdog58, and welcome to the Bolt.Spicer makes various driveshaft end yokes for different trans and rears. Measure twice and cut once.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
