2 members (TUTS 59, 55shaker),
74
Mod | | | Forums66 Topics128,128 Posts1,056,685 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Hey there guys...just another newby here from Idaho with a '58 big window. Hope someone can help me with this situation. I just bought a '69 Camero rear end to put into my truck and will be installing a TH400. What is the best solution for a driveline? Will the original Camero driveline fit right into the TH400? Lil' help here in Idaho. Tired of spending the BIG bucks at the rod shop since this is my third project. Thanks, Steve from Idaho
| | | | | Joined: Dec 2008 Posts: 13 New Guy | | New Guy Joined: Dec 2008 Posts: 13 | Hi bigdog, I too have a 58' but its not a big window =( but I do have a piece of advice for you. even if the splines on the drive shaft fit the rear end and trans the length and drive angles may be askew. so what i would do is measure the distance between the tail comb (output shaft tip) of the transmission and and the yoke of the differential (after installation of course). take this measurement carefully and with info on your diff type and size along with trans info (type) and go to your local diff/driveline shop and they will either fabricate one for you or customize yours. if you are lucky enough the original driveline will fit but those chances are very slim. if at all possible let them make the measurement each shop has dissimilar procedures. However on the other hand if the yoke splines on the drive shaft fit splines on the trans then all you need to worry about is length. be careful if measuring the driveline itself because some shops measure from weld to weld and others from the center of the u-joint bearing caps at each end. hope this helps. | | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | Hello bigdog58,
Torque Wrench is right on, the chances are very slim that your drive shaft will work as is. You won't know for sure, until you get the rear end mounted and give it a try. Your local drive shaft shop should tell you what measurements are needed.
Welcome to the Stovebolt
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Hello, Steve... I can't help you with your driveline question but I'd like to offer up a big and hearty Welcome to the 'bolt  You might want to check out the Engine and Driveline Forum & also maybe try a search & see what you come up with. Here is a link to a Tech Tip for getting the best results when doing a search (it is from the IT Short Bus Forum)  You're in a good place with good folks, make yourself at home. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Welcome to the Bolt,Steve | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | bigdogs are welcome here to  a big hooooowdy and a big welcome to the best dang truck site there is. Lots of info, lots of nice folks....young and old and in between. Make your self at home. | | | | | Joined: Feb 2006 Posts: 346 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 346 | Welcome to the Stovebolt, Steve.
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one. -Ralph Waldo Emerson-
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Hey Steve. Wecome to the Bolt. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Hey Bigdog58, and welcome to the Bolt.Spicer makes various driveshaft end yokes for different trans and rears. Measure twice and cut once.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
