4 members (ndkid275, 2-Ton, Shaffer's1950, Otto Skorzeny), 159 guests, and 1 robot.
Topics128,048
Posts1,055,539
Members48,424
#491377 01/09/2009 4:57 AM
Leo
Offline
Moderator
Moderator
Where do you get this stuff? I tried all the FLAPS in town as well as the hardware stores.
Leo #491383 01/09/2009 5:42 AM
depends on just what you want .... phosphoric acid, a rust remover, may be available from a FLAPS that has a good range of bodyshop/paint supplies .... naval jelly should be available many places .... check CanadianTire, they should have something in the way of rust converters .... or if you're dealing with small parts, you could use the electrolytic setup found here
Leo #491454 01/09/2009 3:09 PM
Ex Hall Monitor
Ex Hall Monitor
<CLICK>
Tiny #491460 01/09/2009 3:30 PM
I bought some "Evaporust" and was skeptical. My results turned out great! I was impressed and will continue to use it. It is rather expensive though. 5 gallons cost around $100.
Builder #491479 01/09/2009 4:39 PM
Leo
Offline
Moderator
Moderator
Thanks. For now I'm trying the electrolysis method, it may be tedious for small stuff, but things are bubbling out in the garage.
Leo #491679 01/10/2009 3:42 AM
Hardware stores and home improvement stores both carry phosphoric acid here. Do y'all have Home Depot or Lowe's up there in the north country?
Cletis #491682 01/10/2009 3:57 AM
Leo
Offline
Moderator
Moderator
Yeah, my daughter works at Lowes. I still prefer the acid bath because I can just throw a bunch of small parts in at once.
Leo #491706 01/10/2009 5:12 AM
Just to let you know, dont use the electrolytic method in an enclosed space. You mentioned in a garage. Hydrogen gas is released (the little bubbles) as the oxygen molecules are transfered between pieces removing the oxidized iron in the process. Theres a serious potential for causing an explosion if the hydrogen has a spark. Just moving the battery charger clamp can create a spark.
Jeff
My 1953 Chevrolet
1947.1 Gallery
I use Ex-Rust by Kano Labs. They are the same people that make Kroil. All their products are great.Check them out @ www.kanolabs.com
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
gtow69 #493384 01/15/2009 3:11 AM
I use a 1:20 mixture of muriatic acid and water. Then rinse with soda ash and water in the garden sprayer to neutralize.
I soak parts in vinegar a few days (in the summer) and even the thickest rust just falls off in sheets. Pour several gallons in a large tupperware container and check it out.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #494365 01/17/2009 3:13 PM
What do ya call that Woodsman, a "Pickled Peck O' Pickup Parts" ????
Denny G
Denny G
Sandwich, IL
Leo
Offline
Moderator
Moderator
I'll try the vinegar method, I already use it to remove lime scale from the coffee maker.
paint and hardware have a blue bottle call osfose or something close its ready to spray and real cheape works good
32fire2 #495896 01/21/2009 3:48 PM
I used B&G Rust Remover. I think it is concentrated Phosphoric acid. It is sold in gallon jugs and is very effective. The supplier that I used is "Automotive Restoration Supplies", with addresses in St. Catherines and Niagara Falls. Phone numbers are 905 934 7140 and 905 892 3341.
Fred
1951 1 Ton Completed
32fire2 #501616 02/04/2009 4:10 AM
Its Ospho
I bought some locally, forget what I paid, but have not used it yet. It is alot less expensive than Picklex or the paint mfg's metal treatments and I bet its all pretty much the same stuff.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
Moderated by  MNSmith
