7 members (Gdads51, NJC, GMCJammer51, 3B, 55shaker, TexasA&M48Truck, 1 invisible),
126
Mod | | | Forums66 Topics128,091 Posts1,056,392 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 7 New Guy | | New Guy Joined: Jan 2009 Posts: 7 | I have a 1976 Mustang 2 front suspension, will it fit in my 1960 Chevy step side? | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | The 60 already has what I thought was a very well designed torsion bar independent front end, right? Would it be necessary to go to the trouble to do a front end swap when you already have an IFS? Just wondering.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | Putting a suspension system designed for a sub-compact car under a truck is sending a boy to do a man's job. It's ill-advised at best, and might be deadly dangerous. Jerry
| | | | | Joined: Jan 2009 Posts: 7 New Guy | | New Guy Joined: Jan 2009 Posts: 7 | You are probable right but I would like to get some disc brakes on it thanks. | | | | | Joined: Jan 2009 Posts: 7 New Guy | | New Guy Joined: Jan 2009 Posts: 7 | Thanks for your response and the info. | | | | | Joined: Nov 2008 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 98 | Check this out...71 chevy pickup crossmember w/discs in my 62, bolts in fairly easy. Crossmember
Last edited by KCMongo; 01/08/2009 6:48 AM. Reason: Inline Image please refer to: http://www.stovebolt.com/forum/gloveguide/pictures.html
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I have a 1960 1/2 ton pickup. I plan on keeping the torsion bar suspension and upgrading to disc brakes. Look under the Chevy S-10 pickups and you will see a torsion bar suspension. I think it will provide a great ride in my 60. But, I can't answer your question. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Builder, only the 4 x 4 S-10's got the Torsion Bar.
Ern, there are disc brake kits available as a bolt-on for a very reasonable price (much less than spending on a conversion)
| | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Here's a link:http://www.gmcpauls.com/60-66_brakes.htm As Scott mentioned above, I have disc brakes on my 60 with dropped spindles. They were on the truck when I bought it, I still have the original torsion bar suspension. They work fine and installing power steering last spring was another great upgrade. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Builder, only the 4 x 4 S-10's got the Torsion Bar. That is correct. The full size 4x4 trucks from '88-'07 (Classic only) also use the torsion bar suspension. However, they share no parts with the '60-'62, the design has its roots in the Toronado/El Dorado front suspension.
Bill Burmeister | | | | | Joined: Jan 2009 Posts: 7 New Guy | | New Guy Joined: Jan 2009 Posts: 7 | Do you know what will fit under my truck,I was told 1970-1975 truck will work. | | |
