5 members (Charles in CA, Gdads51, TUTS 59, moparguy, Woodcmiami), 109 guests, and 9 robots.
Topics128,095
Posts1,056,078
Members48,433
#489705 01/04/2009 3:59 AM
Ern
Offline
I have a 1976 Mustang 2 front suspension, will it fit in my 1960 Chevy step side?
Ern #489740 01/04/2009 5:45 AM
probably not with out quite a few modifications but here's a out fit that has a crossmember kit that you can use your part's on looks good . http://www.streetrodengineering.com/Products/mustangllifskits.htm
old dog #489876 01/04/2009 5:28 PM
The 60 already has what I thought was a very well designed torsion bar independent front end, right? Would it be necessary to go to the trouble to do a front end swap when you already have an IFS? Just wondering.
R-Bo
1966 GMC 305V6 in the family
Ern #489881 01/04/2009 6:10 PM
Putting a suspension system designed for a sub-compact car under a truck is sending a boy to do a man's job. It's ill-advised at best, and might be deadly dangerous.
R-Bo #490656 01/07/2009 2:25 AM
Ern
Offline
You are probable right but I would like to get some disc brakes on it thanks.
old dog #490657 01/07/2009 2:28 AM
Ern
Offline
Thanks for your response and the info.
Ern #490661 01/07/2009 2:46 AM
Check this out...71 chevy pickup crossmember w/discs in my 62, bolts in fairly easy.
Crossmember
Last edited by KCMongo; 01/08/2009 6:48 AM. Reason: Inline Image please refer to: http://www.stovebolt.com/forum/gloveguide/pictures.html
62 mark #490835 01/07/2009 4:36 PM
I have a 1960 1/2 ton pickup. I plan on keeping the torsion bar suspension and upgrading to disc brakes. Look under the Chevy S-10 pickups and you will see a torsion bar suspension. I think it will provide a great ride in my 60. But, I can't answer your question.
Builder #490856 01/07/2009 6:30 PM
Builder, only the 4 x 4 S-10's got the Torsion Bar.
Ern, there are disc brake kits available as a bolt-on for a very reasonable price (much less than spending on a conversion)
Here's a link:http://www.gmcpauls.com/60-66_brakes.htm
As Scott mentioned above, I have disc brakes on my 60 with dropped spindles. They were on the truck when I bought it, I still have the original torsion bar suspension. They work fine and installing power steering last spring was another great upgrade.
Joe
54 Triumph TR2(rhd)needs total resto.
60 Apache 10 stepside shortbed
99 Excelsior Henderson
That is correct. The full size 4x4 trucks from '88-'07 (Classic only) also use the torsion bar suspension. However, they share no parts with the '60-'62, the design has its roots in the Toronado/El Dorado front suspension.
Bill Burmeister
62 mark #501150 02/03/2009 12:35 AM
Ern
Offline
Do you know what will fit under my truck,I was told 1970-1975 truck will work.
