2 members (Jims46, Gray_Ghost), 176 guests, and 0 robots.
Topics128,195
Posts1,057,369
Members48,469
I WAS THINKING IT COULD BE DONE SINCE ITS BASICALLY A 350 WITH 2 CYCLINDERS CUT OFF DOES ANYONE KNOW
remember rust is our friend
We're not deaf, so STOP YELLING!
There's nothing particularly different, or difficult about installing the V-6. Some of the newer ones will need to have the computer harness and all the peripheral stuff like the gas tank-mounted fuel pump, etc. fitted, or some type of conversion to a carburetor and a distributor done. Nothing a master mechanic with a good machine shop, a welding shop, and a lot of time couldn't figure out.
do you half to move the steering box and cut the firewall
V
V Offline
What Hotrod was saying is using all capital letters indicates yelling on the Internet. Use lower case letters in regular posts!
Like they said "yes it can be installed" but it involves alot of work. Welcome!
i know it can be installed and takes alot of work i guess ill half to put it in myself to see if i have to cut firewall and move steering box
24601
24601
Howdy 57chevydelivery and welcome to the 'Bolt, by the way.
We're not trying to give you a hard time here, it's just that you're the first one to ever ask this question (that I know of). I think we're all having a hard time understanding why you would want to do this "upgrade."
Is the original engine bad? Do you have a 4.3L already? Even newer straight sixes, like the 235's from the mid to late '50's are easy to find and would be a heck of a lot easier to install (I just gave one away ...). Even if you already have a V-6, finding a good running pressure oiled 235 (and buying it) is still a preferable solution to the aggravation of trying to make the modern V-6 work.
Just a thought. It's your truck and we're just offering ideas here. Tell us more about this project of yours! Got pictures??
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Just my 2 cents worth, if I was going to the trouble of grafting in a V-engine (which I have) into a big truck, it would be a V-8. The bigger the better. Can never have enough power when hauling with a bigbolt,
Scott
Welcome to the Stovebolt!!!
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Would have to agree with Scott on that one. mounting points should be close to the same. would have to go with the v8 myself again its your truck and your plans. good luck and keep us posted.
Drive with Pride. mike j
family pic
0
0 Offline
The early 4.3 engine was carbureted, although it was an electronic feedback carb so to maintain the emission control system you would need the feedback carb, ECM, harness, engine sensors and oxygen sensor. By early, I mean mid-1980s. You would not need the special fuel tank or high pressure fuel pump. Joe
see i bought a 1948 5 window loadmaster nearly rust free the guy i got it from gave the engine away and i have a 4.3 thats good and complete but i may be better off like you say and go with the inline 6 much easier and cost efficent
Big Bolt Forum Co-moderator
Scott
Like moving barns! eeeek
1948 Chevy 2-Ton
Given how much easier it is to make an inline work in one of these trucks I'd sure rather swap in an inline than a small v-motor.
The 4.3 is going to be all the work and disadvantages of a V-8 but few of the advantages. A 292 inline is going to have better torque, similar horsepower, and be a much easier swap.
But then I'm putting a 500 Cadillac in mine so what could I possibly know...
They make some nice inline diesels too..
What about a 4 cylinder Cummins model 4BT? http://www.4btswaps.com/forum/index.php
Or a 3-53T Detroit?
If you're going to swap something make it interesting and worth doing.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Although it wouldn't be practical, I've thought a straight 8 would be interesting.
I FOUND A 427 TALLDECK TRUCK MOTOR THAT WOULD BE DIFFERENT AND PLENTY OF POWER
1 Offline
5.7 sounds way better to me, these trucks are heavy!
For the purist, inline 6's are still cheap and available.
Last year I aquired a 1/2 ton Chevy with a 4.3 V6. I have become a big fan of them after driving it. I think it would actually be a good performer in the AD trucks with a overdrive transmission and the correct rear end, unless you plan on towing or hauling heavy loads. For cruising and loads 400 to 600 lbs I think it would do a great job. With 160 hp and 230 torque from a stock engine, with all the aftermarket parts made for them I think it would make a nice daily driver (even stock).
When Chevrolet decided to add a turbocharged 4.3L in the Syclone pickup & Typhoon SUV, the vortec headed V6 with multi point fuel injection & some serious boost, both torque & HP were increased to 280 horse power & 360 ft.lbs of torque.
The early throttle body fuel injection I believe only requires 12-13 lbs pressure.
Builder,
The title states that it's a Loadmaster (1 1/2 or a 2 ton). It's already a heavy load, without a load.
Scott
Scott Ward
1 1950 3100
1 1963 K20 (454)
1 1964 C10 (350)
48bigtrucks@work,
Yes, I see that I overlooked that "small" piece of information before I made that entry.
Builder
