2 members (latroca52, 1 invisible),
131
Mod | | | Forums66 Topics128,196 Posts1,057,388 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 36 | I WAS THINKING IT COULD BE DONE SINCE ITS BASICALLY A 350 WITH 2 CYCLINDERS CUT OFF DOES ANYONE KNOW
remember rust is our friend
| | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | We're not deaf, so STOP YELLING!
There's nothing particularly different, or difficult about installing the V-6. Some of the newer ones will need to have the computer harness and all the peripheral stuff like the gas tank-mounted fuel pump, etc. fitted, or some type of conversion to a carburetor and a distributor done. Nothing a master mechanic with a good machine shop, a welding shop, and a lot of time couldn't figure out. Jerry
| | | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 36 | do you half to move the steering box and cut the firewall
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | What Hotrod was saying is using all capital letters indicates yelling on the Internet. Use lower case letters in regular posts!
Like they said "yes it can be installed" but it involves alot of work. Welcome! | | | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 36 | i know it can be installed and takes alot of work i guess ill half to put it in myself to see if i have to cut firewall and move steering box
| | | | | Joined: Nov 1995 Posts: 5,747 24601 | | 24601 Joined: Nov 1995 Posts: 5,747 | Howdy 57chevydelivery and welcome to the 'Bolt, by the way.
We're not trying to give you a hard time here, it's just that you're the first one to ever ask this question (that I know of). I think we're all having a hard time understanding why you would want to do this "upgrade."
Is the original engine bad? Do you have a 4.3L already? Even newer straight sixes, like the 235's from the mid to late '50's are easy to find and would be a heck of a lot easier to install (I just gave one away ...). Even if you already have a V-6, finding a good running pressure oiled 235 (and buying it) is still a preferable solution to the aggravation of trying to make the modern V-6 work.
Just a thought. It's your truck and we're just offering ideas here. Tell us more about this project of yours! Got pictures??
Regards, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Just my 2 cents worth, if I was going to the trouble of grafting in a V-engine (which I have) into a big truck, it would be a V-8. The bigger the better. Can never have enough power when hauling with a bigbolt, Scott
Welcome to the Stovebolt!!!
| | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Would have to agree with Scott on that one. mounting points should be close to the same. would have to go with the v8 myself again its your truck and your plans. good luck and keep us posted. | | | | | Joined: Mar 2007 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 64 | The early 4.3 engine was carbureted, although it was an electronic feedback carb so to maintain the emission control system you would need the feedback carb, ECM, harness, engine sensors and oxygen sensor. By early, I mean mid-1980s. You would not need the special fuel tank or high pressure fuel pump. Joe | | | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 36 | see i bought a 1948 5 window loadmaster nearly rust free the guy i got it from gave the engine away and i have a 4.3 thats good and complete but i may be better off like you say and go with the inline 6 much easier and cost efficent
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Just my 2 cents worth, if I was going to the trouble of grafting in a V-engine (which I have) into a big truck, it would be a V-8. The bigger the better. Can never have enough power when hauling with a bigbolt, Scott
Welcome to the Stovebolt!!! Like moving barns!  A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Given how much easier it is to make an inline work in one of these trucks I'd sure rather swap in an inline than a small v-motor.
The 4.3 is going to be all the work and disadvantages of a V-8 but few of the advantages. A 292 inline is going to have better torque, similar horsepower, and be a much easier swap.
But then I'm putting a 500 Cadillac in mine so what could I possibly know...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | They make some nice inline diesels too.. What about a 4 cylinder Cummins model 4BT? http://www.4btswaps.com/forum/index.phpOr a 3-53T Detroit? If you're going to swap something make it interesting and worth doing. Grigg | | | | | Joined: Dec 2003 Posts: 265 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 265 | Although it wouldn't be practical, I've thought a straight 8 would be interesting. | | | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 36 | I FOUND A 427 TALLDECK TRUCK MOTOR THAT WOULD BE DIFFERENT AND PLENTY OF POWER
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | 5.7 sounds way better to me, these trucks are heavy! | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | For the purist, inline 6's are still cheap and available.
Last year I aquired a 1/2 ton Chevy with a 4.3 V6. I have become a big fan of them after driving it. I think it would actually be a good performer in the AD trucks with a overdrive transmission and the correct rear end, unless you plan on towing or hauling heavy loads. For cruising and loads 400 to 600 lbs I think it would do a great job. With 160 hp and 230 torque from a stock engine, with all the aftermarket parts made for them I think it would make a nice daily driver (even stock).
When Chevrolet decided to add a turbocharged 4.3L in the Syclone pickup & Typhoon SUV, the vortec headed V6 with multi point fuel injection & some serious boost, both torque & HP were increased to 280 horse power & 360 ft.lbs of torque.
The early throttle body fuel injection I believe only requires 12-13 lbs pressure. | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | I think it would actually be a good performer in the AD trucks with a overdrive transmission and the correct rear end, unless you plan on towing or hauling heavy loads. Builder, The title states that it's a Loadmaster (1 1/2 or a 2 ton). It's already a heavy load, without a load. Scott | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | 48bigtrucks@work,
Yes, I see that I overlooked that "small" piece of information before I made that entry.
Builder | | |
