Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 64 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#490722 01/07/2009 5:10 AM
Help! I have some panels that are rusty on the back side. I'm sure that they blast through if I had them sand blasted. I would like to grind off the heavy rust and then coat with rust converter. Would it be a waste of time and money? Are rust converters all the same?
Don
You might do a web search to see if anyone has done a comparative study on the subject. I use Loctite's product and have had good results with it. Eastwood and others market a similar product.
~Jim
I used Eastwoods 2 part brush/spray rust converter it worked really well and then followed up with a coat of Eastwood Rust Encapsulator ....was well pleased with how they worked together.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #491013 01/08/2009 4:19 AM
Thanks for the ideas. There are a lot of choices on the web. One part, two, three . . . amazing. Not sure yet what I will use. I am incouraged that this stuff really does work.
Don
Go to your local autobody supply store and see what they have. Mine has SEM products which works well,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
