| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | Help! I have some panels that are rusty on the back side. I'm sure that they blast through if I had them sand blasted. I would like to grind off the heavy rust and then coat with rust converter. Would it be a waste of time and money? Are rust converters all the same?
Don | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You might do a web search to see if anyone has done a comparative study on the subject. I use Loctite's product and have had good results with it. Eastwood and others market a similar product.
~Jim
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I used Eastwoods 2 part brush/spray rust converter it worked really well and then followed up with a coat of Eastwood Rust Encapsulator ....was well pleased with how they worked together. Tim | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | Thanks for the ideas. There are a lot of choices on the web. One part, two, three . . . amazing. Not sure yet what I will use. I am incouraged that this stuff really does work.
Don | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Go to your local autobody supply store and see what they have. Mine has SEM products which works well, Scott | | |
