4 members (Bill Hanlon, baldeagle, Greg_H, Guitplayer), 121 guests, and 1 robot.
Topics128,037
Posts1,055,469
Members48,424
#459752 10/09/2008 3:46 AM
How do you remove rivets? I am trying to remove the leaf spring brackets and front transmission crossmember. they are riveted to the frame. I have cut one end off of a few using a cutoff wheel. They won't budge from the punch and hammer. Do I need to drill them out after cutting the heads off? This is on a '48 panel.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Drill about 1/16-1/8" smaller than the rivet size, but don't drill the last 1/8-3/16", then try a slightly loose fitting punch inside the hole.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #459757 10/09/2008 3:56 AM
If you have been using a punch and hammer after cutting off the head then you're using too small a hammer and punch. I would suggest you get a 12 or 15 inch punch and use a short handle sledge about 4 lbs. One or two licks with that and the remaining rivet will shoot across the room.
~Jim
I find drilling easier than grinding.
I usually drill a small hole, like 1/8th, followed by a larger one closer to the size of the rivet. I find they punch out faster if that larger hole is all the way through the frame, but not the rivet.
Good sharp bits and some lubrication make it go fast. Last time I had a bunch to do I used two drills so I didn't need to swap bits, but could just keep moving.
Then a punch smaller than the hole will drive the rivet right out.
My preferred method for rivets up to 3/8" diameter is a 1" wide cold chisel about 12" long. Followed by a similarly stout tapered punch. both driven by a small sledge (actually an engineers hammer) with an 18" handle. If you're not scared to swing a hammer this method works quickly, about 3 or 4 licks to shear the head off, and one more to pop the remainder out of the hole. I removed a few dozen from my 2 ton frame, and then reinstalled almost as many new rivets.
Grigg
---All pictures---
Grigg #459878 10/09/2008 5:57 PM
For and old man like me OLDSUB has hit the rivet on the head grin
(Pun intended)
Griggs idea works fine but I"m scarrrred! wink
Achipmunk #459892 10/09/2008 6:47 PM
I use a torch to melt the heads off. It takes about 5 seconds and out it pops with one swing of the hammer.
For some of us who have screwed up hands youll save yourself some pain and vibration from the impact of the hammer.
My 1953 Chevrolet
1947.1 Gallery
rustednuts #459897 10/09/2008 7:01 PM
I was gonna say. Drilling is my prefered method. After years of wrenching, my hands are starting to feel tired. So the less hammering I can do, the happier I'll be!
MNSmith #459962 10/09/2008 11:31 PM
my preferred method is to drill also. i drill a 1/4 " hole into the center of the rivit going a little deeper than the head.then take a sharp chisel and after about three or for wacks with a medium to large ballpein they slice right off.then with a tapered punch a couple more wacks takes em out real slick like.................dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
I tried drilling a few. Start with a small bit, and redrill with a larger bit. Couldn't get it dead center, some the drill won't fit right over. I ground those heads off, and one I hadn't drilled and it went just as fast. I could see a hairline crack between stud and frame, so I know I could center a hole on that. I'm tempted to use an air chisel, but I would need to get more tools, not a bad thing. That punch is about ten inches, I'll see what the sledge can do with it. I don't plan on using the holes when I'm done, but the less damage the better.
In Project Journals
In the DITY Gallery
waveI prefer to use a air hammer, with a sharp chisel. Watch out it will knock them heads off real quick, then take a punch and and they will come flying out. From the air hammers viberation, it busts that rivit loose to where you can use a punch and hammer and drive it on through. That worked the best for me, and it makes for a real quick job. thumbs_up
mo2cyl #460012 10/10/2008 1:40 AM
I have tried the air chisel, but at least the one I had, a really nice Snap-on, was not as good as the big hammer and chisel. The air chisel stretched the holes more than the big hammer and chisel.
the air hammer with a punch tool did work pretty slick for punching them out though.
I was concerned with damaging things because I did reuse most all of the holes.
I think it's been said before, but no one way works all the time.
Best to have a a few plans of attack for those stubborn or hard to get to rivets.
Grigg
---All pictures---
Grigg #460662 10/12/2008 2:20 AM
Drill it out, then have two air hammers, one with a chisel tip the other with a punch. Drill a pilot hole, drill out the rivet, cut the rivet head off, then punch it out. With two drills and two air hammers, you can make some rivets fly.
I've got some to do tomorrow...
R-Bo
1966 GMC 305V6 in the family
R-Bo #461248 10/14/2008 3:41 AM
I agree with you guys with the busted knuckles, the hammer can be painful. I don't hold the chisel or the punch with my hand, I use a big Vise Grip to hold the tools while I swing.
~Jim
The best way that I found was to first burn the heads off with the smoke wrench.Then grind it smooth.Next use an air chisel with a punch bit,and push it thru.
Grigg #461941 10/16/2008 3:33 AM
Apprentice
Apprentice
I've always been a hammer/chisel sort, myself. Then punch 'em out. Keep your cold chisel sharp. It's a method best mastered with time, concerning angle, not smashing your knuckles, etc. grin
Grigg
Where did you get new rivets that size? I could use new ones in a few places, but I have no idea where to get something like that. Thanks!
~Bruce
oc51 #461944 10/16/2008 3:40 AM
My fist choice is: http://www.mcmaster.com/
search for: Rivet
Page 3227
Second choice, and for the sizes that McMaster does not have: http://www.bigflatsrivet.com/
Grigg
---All pictures---
Grigg #461949 10/16/2008 3:48 AM
Apprentice
Apprentice
Excellent! Thank you so much. You've been a good source of info on other things, Grigg. I spend a lot of time reading these forums, and have not gone to bed once without learning something! Thanks again.
~Bruce
oc51 #462651 10/18/2008 4:17 AM
Grinding the heads off was easy, but wasn't enough. I found drilling works best for me. I started a tap hole, and gradually increased drill bit size until the heads came off. Drilling through past the frame for the smaller bits, and just to the bottom of the heads with larger bits. Then pound them out with hammer and punch. I got some new 1/8" drill bits, a drop light, center punch, and chuck key. Why I even tried without those basics?
In Project Journals
In the DITY Gallery
1 Offline
plasma cutter works great also! the sharp chisel and BFH method seems to be "the proven method" with me also. but those BFH'S are getting tougher to swing these days. scarfing tip on cutting torch works well.
I cut an X across the head with a cut-off wheel, then shear the head off with a cold chisel, followed by a tapered drift/punch to remove the body of the rivet.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
