8 members (delwrench, crenwelge, 2-Ton, Cletus1950, Jay R, Hugh63c10, 1955 1 Series, amtrakjoe), 338 guests, and 6 robots.
Topics128,159
Posts1,057,027
Members48,460
How do I replace the door handle "anti-droop" springs in my 1941 Chevy Pickup? These are parts that Jim Carter sells. They are on page 21.
Please assume that I am totally clueless, because I am!
Thanks for your help!
I'll be watching this one myself... my '37's handles are getting a bit droopy too so I'll have to do this job sometime soon too... frown
~Trev
Ex Hall Monitor
Ex Hall Monitor
Hey, we all get a little droopy as the years go by. grin
I have NOT done my yet but have the new springs to do it. Its been a while since I had one of the door latches apart but I think it was relatively simple if I remember correctly. BUT sometimes the problem is not the spring but the "square" hole the handle fits in gets "rounded" out some.
If the square hole is the problem I have read over the years that some guys "weld" the holes up some and then file them back out. One guy put his handle in a vice, heated it up and BENT the handle.
Don't be afraid to tackle it. I hate taking it out more than I do working on them!!
That's the way I did mine, Alvin, Bill, Trev and Tiny. I heated the square shaft that goes through the hole in the latch and bent it so the "droop" is gone. It worked great! And Alvin is right. The spring won't do any good if the square hole in the latch is worn or if the shaft on the handle is worn. That is usually the problem, consequently that spring cannot correct the wearing.
Joe thumbs_up
Hey Alvin, maybe just Drill a big Ol hole in the top of the door stick an eye bolt in there an use a bungee strap to hold the handle up ???...LOL !!!!..ya know Im just foolin !...but that would be soem serious REDNECK engineerin!...hehehehee
Tim
1952 Chevy Shortbed
Photos in Photobucket
I just did this a month or so back, and I cant remember!!!
I do remember that the problem wasnt the wear factor, but that so much gunk had built up in the latch mechanism that it wouldnt return properly. I washed and scrubbed it up with wd-40 then greased all the moving parts and they now work great.
Can you take a picture of the mechanism? It would probably refresh my memory.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Moderated by  ndkid275, Phak1
