| | | Forums66 Topics128,146 Posts1,056,795 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | I need to fill my newly rebuilt rearend with oil; what do you guys recommend? It's a 1975 chevy 12-bolt.
Thanks in advance! | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I use good old 90 weight. Tim | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | | | | | | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | Thanks, guys!
Next question: how much do I need to put in it? I tried Advance, they couldn't tell me.
Also, the rearend cover has no drain or fill holes; how the heck am I supposed to get it in there? Through the vent, I suppose? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | there is a pipe plug on the differential housing on the passengers side behind the universal yoke, you will see the hole is square use an extension 3/8 or 1/2 i cant remeber but that will remove it. after removing the plug fill the rear until lube runs back out the hole (that is the full level) replace the plug (use teflon tape on plug) and your DUN! Tim | | | | | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | Thanks, man! Do you think that two bottles of oil would be enough to fill it? Or would I need more? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | yes 2 bottles will do , Im pretty sure if its dry a little over a qrt. is needed | | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | thanks to this thread i just figured out that i was trying to fill my rear end improperly. i was trying to fill it through the vent hose instead of through the hole in the passenger side haha. | | | | | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | thanks to this thread i just figured out that i was trying to fill my rear end improperly. i was trying to fill it through the vent hose instead of through the hole in the passenger side haha. Dude! I was about to do that myself! Sure enough, it was almost exactly two bottles. There isn't but about a 1/4" left in the second bottle. It's a 3/8" drive rachet that will open the plug as well. Thanks for the info, Radial. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | That is what this place is for Gents!...you have no IDEA how many tips & tricks Ive learned here...KEEP ON BOLTIN! Tim | | |
