0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
#426943 06/26/2008 8:09 PM
I need to fill my newly rebuilt rearend with oil; what do you guys recommend? It's a 1975 chevy 12-bolt.
Thanks in advance!
Mike from Alabama
My truck on Stovebolt
My website
Why do we drive on a parkway, and park on a driveway?
I use good old 90 weight.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Hypoid 85w90
Thanks, guys!
Next question: how much do I need to put in it? I tried Advance, they couldn't tell me.
Also, the rearend cover has no drain or fill holes; how the heck am I supposed to get it in there? Through the vent, I suppose?
Mike from Alabama
My website
there is a pipe plug on the differential housing on the passengers side behind the universal yoke, you will see the hole is square use an extension 3/8 or 1/2 i cant remeber but that will remove it.
after removing the plug fill the rear until lube runs back out the hole (that is the full level) replace the plug (use teflon tape on plug) and your DUN!
Tim
1952 Chevy Shortbed
Thanks, man! Do you think that two bottles of oil would be enough to fill it? Or would I need more?
Mike from Alabama
My website
yes 2 bottles will do , Im pretty sure if its dry a little over a qrt. is needed
1952 Chevy Shortbed
thanks to this thread i just figured out that i was trying to fill my rear end improperly. i was trying to fill it through the vent hose instead of through the hole in the passenger side haha.
Dude! I was about to do that myself!
Sure enough, it was almost exactly two bottles. There isn't but about a 1/4" left in the second bottle. It's a 3/8" drive rachet that will open the plug as well. Thanks for the info, Radial.
Mike from Alabama
My website
That is what this place is for Gents!...you have no IDEA how many tips & tricks Ive learned here...KEEP ON BOLTIN!
Tim
1952 Chevy Shortbed
