1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | ..........can cause major headaches. I thought I'd go ahead and prime the oil pump since the motor hadn't been started in awhile. I rented the tool from Autozone and attached to my drill and began what should have been a very simple task. To me suprise, oil began to pour from the engine! I must have lost a quart and I couldn't figure out what the heck was going on. I discovered that I had left the oil pressure sending unit off the back of the motor. No problem right? Wrong!! I'm using a set of 5" Haneline guages and the sending unit will not clear the back of the intake. There were adapters that came with it but they to will not clear. I might be able to modify one of the fittings by shortening it and adding a short hose on one end and the sending unit on the other. Anybody know how much pressure will build up and if the hose will work?
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | can you not find an "elbow" that would get you clear.... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I am reading this with great interest. I have bought the primer tool (instead of renting duh) and will be doing the same thing as you are doing. Hopefully following you through the mine field will help me avoid the lost of oil et al.
~Jim
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I checked mine out and I used about a 1 1/2" or 2" nipple and a 90 and put the sending unit in the 90, I tried taking a picture but it's real cramped in there and the pic turned out blurry Hope this helps Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I had the same problem, I put mine above the oil filter. There should be a plug to remove and install the sender. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I had thought about Wilbur's side mount above the filter but it will be a shorter run and neater fit on the back. However I'm afraid when the cab is on there won't be enough room even for a elbow fitting.
~Jim
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | yes i had to do some plumbin also with mine to get the clearance ..as it was to tight to the firewall ...almost ordered a mechanical gauge ...with those the routing of the line is simple and clearance is not an issue. but the electric senders can be a pain ...I dont know why they have to be so big! lol Tim | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I used a 90 bend on mine after checking with Stewart Warner. Oil Presuure reads fine. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | There were elbows supplied with the sending unit. The problem is that the stud is too long. I'm checking for a shorter one. I didn't know about the one above the oil filter. I'll see if that gives me more room to work with.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | mobileortho This is funny as I actually had same issues a couple of weeks ago. Go to your local FLAPS as they have longer and shorter pipe nipples, 45 & 90 degree bends etc. that can be used to make it fit into a "open" area. Good Luck
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Problem solved! Went by Lowes today and found a shorter nipple and was able to git er done!
