1 members (Rich'sToys),
90
Mod | | | Forums66 Topics128,079 Posts1,056,310 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 35 | Anybody done a big back window conversion on there 60-66 truck? I have the small back window and would like a big back window. It is hard enough to find a decent cab for these years, and even harder to find one that has a big back window.
I figure the only way is to find a wrecked or rusted up big back window cab and somehow cut out the back window and fit in my little cab back window.
Anyone with experience in this area, I could use some advice. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I've done one on my 63. The part that needs changed is the inner panel in the rear of the cab. The window opening is the only thing needed changed on the outside. All you do is cut out the hole bigger. On the inside, you will need to drill all of the spot welds holding the inner panel to the cab and cut it from the roof panel. Swap it out with a rear panel from a big window cab (which I have one) and you're done. If you're interested in my panel, PM me and we'll talk, Scott | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Wow ! Looks awesome ! good job so far Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: May 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 35 | Here is a link to a web site that I am working on that describes the process of converting a small back window to the large back window on the 60-66 chevy trucks. http://1958evinrude10hp.0catch.com/60-61BackWindowProjectPg1.htmlLet me know what you think so far. Thanks to Scott for the big window panel. | | |
