9 members (treegrower, 68ironhead, GRNHydra, Nhluvstruck, 55shaker, MickeyP, elhippie64, David Bush, 1 invisible),
43
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 23 Apprentice | | Apprentice Joined: Dec 2007 Posts: 23 | Will a 350 run OK in a test stand with only a flexplate for a flywheel?
Bob | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Bob B, yes it will, just make sure it is torqued into position, hope that helps. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Interesting. I would have thought the engine would need the mass or weight of a conventional flywheel, or of a flex plate/torque converter combination to idle properly. Maybe you don't idle an engine on a test stand.
Stuart | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | The ultra-lightweight 3-disc clutches we use on the round track engines use a flex plate so a starter can crank the engine. Those clutches are about 6 inches in diameter. I would assume an engine with a stock camshaft would not like to slow idle with only a flex plate, but above 1,500 RPM or so it should run OK. Jerry
| | | | | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | The engine will set very still, you will be suprised how little it moves. There is not resistance for it to torque up against. I have run a bunch of Pontiacs on a stand I built, they dodn't even vibrate around. Make sure you have a fan on the radiator or the engine fan pulling air, they get hot pretty fast and require more air flow then you think. Joe | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | In the car club we did it for several years on a trailer we used to pull the engine to cruise-ins. We had local built to a couple of the crate engines and never had a problem. | | | | | Joined: Dec 2007 Posts: 23 Apprentice | | Apprentice Joined: Dec 2007 Posts: 23 | Thanks for the replys. Looks good for a test run with just a flexplate. This an '86 carburated 350 so should be an easy setup.
Bob | | |
