2 members (Peggy M, Gray_Ghost), 184 guests, and 1 robot.
Topics128,089
Posts1,056,116
Members48,434
#411745 05/11/2008 1:47 AM
Apprentice
Apprentice
Will a 350 run OK in a test stand with only a flexplate
for a flywheel?
Bob
3B Offline
Hy Bob B, yes it will, just make sure it is torqued into position, hope that helps.
3B #411806 05/11/2008 4:26 AM
Interesting. I would have thought the engine would need the mass or weight of a conventional flywheel, or of a flex plate/torque converter combination to idle properly. Maybe you don't idle an engine on a test stand.
Stuart
H Online: Content
The ultra-lightweight 3-disc clutches we use on the round track engines use a flex plate so a starter can crank the engine. Those clutches are about 6 inches in diameter. I would assume an engine with a stock camshaft would not like to slow idle with only a flex plate, but above 1,500 RPM or so it should run OK.
The engine will set very still, you will be suprised how little it moves. There is not resistance for it to torque up against. I have run a bunch of Pontiacs on a stand I built, they dodn't even vibrate around. Make sure you have a fan on the radiator or the engine fan pulling air, they get hot pretty fast and require more air flow then you think. Joe
Joe H #411966 05/11/2008 10:50 PM
I broke in a 283 on a stand without a problem, and it ran very smooth with the flexplate. http://i290.photobucket.com/albums/ll273/aggieranch/100_0879.jpg
Spencer
In the car club we did it for several years on a trailer we used to pull the engine to cruise-ins. We had local built to a couple of the crate engines and never had a problem.
Apprentice
Apprentice
Thanks for the replys.
Looks good for a test run with just a flexplate. This an '86 carburated 350 so should be an easy setup.
Bob
