| | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 75 | Is thier any difference in six cyl distributors. I want to put an h.e.i. in my 65-292. I have one out of a smaller- newer 6 cyl. Will it fit in mine. Thanks. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I understand that it will fit with some minor modification to the base. Why not do a Petronix set up and keep what you have? Same benefit. | | | | | Joined: Mar 2004 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 75 | Moneypit thats a Very good idea I didnt even think of it. Thanks Lou. H. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | i thought all chevy dist. from 194-292 were the same? all that is different with 292 is deck height,motor mount and fuel pump location. probably best to do a side by side visual on the 2 dist. | | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | chevy put hei on the 292 starting in the mid 70s or so. i found one for my 292 out of a late 70s truck with a 292. fit perfectly. | | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | What about the older 6 cly? I have a '62 235. Can I get a junkyard HEI that'll fit ? Thanks. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | on my 38 a distibutor from a 1981 chevy six worked fine. dropped right in. however I scavenged one from a step van that did not fit my 54 so i tried the one from the 38 it also didn't fit properly wouldn't engage the oil pump. the 38 still has the 216 the 54 a 235
