3 members (Wheelie, 1955 1 Series, Otto Skorzeny), 40 guests, and 6 robots.
Topics128,012
Posts1,055,315
Members48,419
#402945 04/16/2008 2:33 PM
Is thier any difference in six cyl distributors. I want to put an h.e.i. in my 65-292. I have one out of a smaller- newer 6 cyl. Will it fit in mine. Thanks.
I understand that it will fit with some minor modification to the base. Why not do a Petronix set up and keep what you have? Same benefit.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Moneypit thats a Very good idea I didnt even think of it. Thanks Lou. H.
1 Offline
i thought all chevy dist. from 194-292 were the same? all that is different with 292 is deck height,motor mount and fuel pump location. probably best to do a side by side visual on the 2 dist.
chevy put hei on the 292 starting in the mid 70s or so. i found one for my 292 out of a late 70s truck with a 292. fit perfectly.
What about the older 6 cly?
I have a '62 235. Can I get a junkyard HEI that'll fit ?
Thanks.
on my 38 a distibutor from a 1981 chevy six worked fine. dropped right in. however I scavenged one from a step van that did not fit my 54 so i tried the one from the 38 it also didn't fit properly wouldn't engage the oil pump. the 38 still has the 216 the 54 a 235
Socket Breaker
Socket Breaker
Thanks.
topcat:
http://www.stovebolt.com/techtips/hei_conversion.htm
http://www.stovebolt.com/techtips/HEI_mini.html
or you can call these folks and tell them what engine you have and so forth:
http://www.pertronix.com
-W
