7 members (RoadsScholar, Hanks custodian, thekid1950, Peggy M, Hotrod Lincoln, dt235sd, Thomaslb), 193 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
Apprentice
Apprentice
I should be getting My new windshield soon,I have replaced windshields in tractor trailers before so I have some experience,But have never put one in an old pickup.Any tips on how to go about it would help.Thanks
All you need is a new window seal, small diameter rope, silicone spray and a couple of extra hands to help. Install the seal on the glass, wrap the inner part of the seal with the rope and spray the seal with silicone. Set in place with the rope to the inside of the cab and have the extra hands applying pressure from the outside. Start pulling the rope so the seal flips over the flange of the cab while a helper follows you from the outside. It should go quick on a 65, the 63 and older trucks windshields wrapped around the A pillar and made it a bit more difficult to install.
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I prefer to use personal lubricant over silicone spray, it is water based and doesn't interfere with future paint jobs.
Paint & Body Shop moderator
Please guy's, get away from this silicone spray! It's the work of the Devil! nono
I agree silicone sprays have their uses but not in this instance!
I fit glass for a living and never use anything other than plain old glass cleaner. It wont 'hurt' the paint finish or the rubber!
4ontheFloor's right, silicone will contaminate your paint and may cause problems for any future paint remedial work!
Good Luck
Jock thumbs_up
More pix on Flickr.
Just had all the glass installed in my 64 Suburban Friday. Well worth the $150. Included windshield with molding(needed many hands!), rear door one piece gaskets, rear quarter windows with one piece gaskets, and removal and reinstallation of my second(slider) windows that already had rubber on them, but I'd forgotten to put the cushion pads under the frames. They used window cleaner.
I've got a guy that does this glass stuff for a living and he's been here at the house on several occasions installing my glass. Never anything more than a good quality glass cleaner and his rope with a window stick. Just last week, watched him put a new glass in an 80' LUV, start to finish...12 minutes. My bill...$100. Best money ever spent for the prevention of rectal irritation in my opinion.
dj durant
More pix on Flickr
