6 members (GMCJammer51, Greg_H, NorCal52Suburban, Hush, Cosmo, 1 invisible), 70 guests, and 2 robots.
Topics128,073
Posts1,055,908
Members48,429
Houston54
Unregistered
Houston54
Unregistered
Did a mock up of what louvers on the side of my 54 hood would look like. Talking with the rod shop that will do the work, getting the alignment/positioning correct will be challenging but the location I show in in the attached pics is close to what I think will work well.
http://www.picturetrail.com/gallery/view?p=999&gid=19310886&uid=2902753
The mock up only shows nine louvers but the total count would be closer to 12-14.
What do you think of the look? Remember this forum is the Hot Rod hang out so if you are against body mods on these truck you may have taken a wrong turn somewhere.
jdl Offline
Hmmmmmm. Maybe if you had a picture showing more of the truck? I can't seem to form an opinion based on just that picture. I do, however, have very little doubt that if it's done right, it will look good.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
H54,
I like the louver look. If you end up with more than the 9 showing in the picture I think it will look better. Kinda evens things out. I think they have to be off centered to look right also. Good luck and have fun. Your truck looks great!
Dan
Do it.
its not hateful,mybe more would problylook better.definatley a louver fan though.like i said not awful......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Louvers look pretty good, but I can tell you from experience they are a real pain in the a$$ to keep your engine clean. I had a 1952 Chevy Bel Air hardtop with a whole bunch (I forgot how many) of them. When I washed it the engine would get soaked, sometimes even wouldn't start because of a wet distributor.
The vertical on the hood with horizontal on the cab might look a little odd, but it's your money.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
Houston54
Unregistered
Houston54
Unregistered
"Horizontal on the Cab" Who would put louvers on the cab? The plan is for a single row of slats on the sides of the hood only.
The comment about water getting on the engine is valid but I think with only one row on the sides there should not be too much of a problem. I have some stainless mesh that will be installed behind the louvers to keep bugs out.
Thanks for the comments
Point them the other way and make hood scoops out of them,
LOL,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Quote ["Horizontal on the Cab" Who would put louvers on the cab?] headscratch
The Plant that manufactured your truck - that's who. eek
(where the fresh air intake for the heat is - between the passenger door, and front fender.) thumbs_up
Quote [Be Blessed With Faith, Family, Fun & Fat Fenders.]
What - no friends? I see why. smile
David Colter
Houston54
Unregistered
Houston54
Unregistered
If I wanted to have them on the cab I would not have shaved them off to begin with but then you are not that observate to begin with so you are forgiven.
As to your other comment - my friends chose their friends very selectively based on trust. You might try that sometime there turnip.
jdl Offline
Ok, ok, guys. COOL IT! Please!
Jordan D. Long
Photobucket
OK here's my thought, You have went through a lot of work and have a great looking truck that anyone would be proud to drive down the street. You kept it with the smooth appearance which i really love. Now the addition would make it stand out in the crowd but it already does that. Would you make the louvers all the same size or taper them down after about half way going to the back? My opinion would be to leave it as is. But its your truck and your choose, What ever you decide it still is a great looking ride.
The boy (Ray) wants to know if you used the carpet?
Have a great one hope to talk to you soon
Drive with Pride. mike j
family pic
It's your money - spend it how you wish. I don't need input in the "turnip patch". Apparently money gives you an excuse for being rude. So - I am glad I am poor and kind. You asked for input. I put the last issue behind us, and gave you an honest answer with the picture you provided. I forgive your ignorance, but not your attitude. Are we supposed to research every detail of a person's truck before replying?
As to the other comment - you can dish it out, but you can't take it?
I am quoting you - "If you would get off your high horse and look at the end of my post you would see something that MOST everyone else would recognize as an icon that means that it was intended as a joke or at least a not so serious reply. It is kind of refreshing to have such a newbie on the site but on the other hand to have someone like you show up and start with their holier than thou crap makes me think you need to stay in the turnip patch. If you don't like something you read here then tough it out there tex. If you are looking for hugs and kisses all the time then wise up. You ain't going to get it here or anywhere else."
wink
Your favorite turnip,
David Colter
Houston54
Unregistered
Houston54
Unregistered
Dakota - I have not pulled the trigger on the carpet as yet. Been working the wiring and deciding on the gauges. One concern I have on that carpet though is that being marine grade it has a rubber backing which may trap moisture under the carpet should any get there. I will need to discuss this with the shop I select to do the seat cover. If it is not needed I will certainly get it back to Ray. Hope you are thawing out up there.
As to the louvers, the shop only has one size die and that is 3 inch. I think a tapered size from say 4 inch down to the 3 inch size shown in the picture would work well. I have my own concerns on the louvers and think the truck would look good either way. The main problem is trying to establish a reference point on the inside of the hood as the puover are punched from that side. I have an extra hood which has too many issues to use which I will use as a test case. If that does not work out well I will pass on punching this hood and get this truck done.
JDL - calm yourself
54Turnip - your forgiveness is not requested or desired. I truly doubt you are as ignorant as you appear to be but do us both a favor and do not offer your opinion to any of my future queries. To put it bluntly you have nothing to offer.
Houston, Your engine attracts bugs?
It doesn't quite sing for me. It's a matter of personal preference though. It's your truck, so do what you like. It might grow on me!
I wouldn't kick it out of the garage for eating crackers. grin
CJ
OK, noughs enough, It is YOUR ride!!!!...make it Yours!...it is what makes this Hobby FUN!.
If YOU like the Mod? ..Who the Heck am I to comment on whether it is right or wrong?
That simply is not my place.
What trips my fancy might be totally on the reverse side of most others...How many Bright White AD's do ya see like I am doin mine?
So to get to the point ITS YOUR TRUCK, build it as you see fit an like, THE REST IS POLITICAL BULLCRAP!
KEEP ON TRUCKIN!
Personally I cant wait to see the Pics of the Louvered Hood dressed out in Color!...It may be AMAZING!...
SOMETHIN DIFFERENT CAN BE GREAT! Everyone Especially ME likes to see Inginuity!
just my 2 pennies.
Tim
1952 Chevy Shortbed
Photos in Photobucket
I agree, Tim, good points!
Houston54
Unregistered
Houston54
Unregistered
Good points indeed and that is why I have done the truck as I want to this point however this mod finds me on the fence. I was hoping to get input from others who have done louvers as to any negatives associated with them as well as getting a perspective on what the hot rod contingent here on the bolt thinks of the visual impact. I have received worthy opinions from some and other opinions that...well enough said.
The key comments have focused on the location of the louvers with several saying they need to start further back on the hood to which I agree but also have to work around the rear hood bracing.
ODSS President
ODSS President
C Online: Content
KEEP ON TRUCKIN!
just my 2 pennies.
Tim
Yeah, (I think you're going to love it). I've been mulling over doing the same thing only farther back (as you said the positioning would be) doing six a side for a Stovebolt Six....I guess you could do eight for an 'Excellent Eight'.
~ Cosmo
1949 Chevy Half Ton
Houston54,
I take it by your handle that you live in Houston (as do I). I have a 56 PU that I am looking to get some louvers done on, what shop did you find to do it?
thanks and regards,
Wirewheelz
Houston54
Unregistered
Houston54
Unregistered
Welcome to the bolt there Wire!
There is a rod shop in the Klein area that specializes in 32 Fords. The name of the shop is Bruce's Rod Shop. Ask for Danny.
thanks for the info, I'm a ways away from making any decisions on louvers. I just picked up my '56 here in Houston, it was a
'rod project that got started but is no where near completion. I have all the sheet metal in the garage and will be trailering the frame/cab home soon. I moved down to Houston about a year 1/2 ago from the Boston area and since I'm in TX, I need a PU, right? So why not go w/something stylish. Mine is a big window LWB with a MII front end and a fresh 327 so it looks to be a good place to start. I'm a bigger fan of the SWB, so I'll probably be looking to cut the frame down, etc. Love the board so far, can't wait to start bruising my knuckles....
