7 members (55shaker, dt235sd, Hanks custodian, NJC, 3B, Gdads51, 1 invisible),
211
Mod | | | Forums66 Topics128,086 Posts1,056,098 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 6 New Guy | | New Guy Joined: Jan 2008 Posts: 6 | Hi All Have any of you tried the Dupli Color paint that is sold at the parts store. It's susposed to be great for the garage guy.I've seen it shown on Speed vision and it looks ok. But is it? Please let me know what you think, thanks Harry | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Never tried it, but I have used some of their other products with ery good results. I have heard good things about it on another site I frequent. The only real drawback I see to it is the limited color availability, and it seems that some places don't carry certain colors, or at least in my area they don't. I think alot of it really comes down to the surface prep as far as results go, regardless of what you use.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm a dupli-color fan. It is a bit pricer than some of the stuff but I do like it. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I use their self-etch primer... it's good and it's convenient in the rattle can. I also like the fan pattern spray. Good stuff. | | | | | Joined: Jan 2008 Posts: 6 New Guy | | New Guy Joined: Jan 2008 Posts: 6 | How about the sprayable stuff? I understand it can be clear coated also, or left alone. | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | Same here on the fan pattern. Used their Anodized silver on the headlight bulb retainer (the inner piece) and came out great!
Mike | | | | | Joined: Dec 2007 Posts: 166 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 166 | I have used the dupli color " purple " for my customers rims on her bus. The stuff was very consistant, easy fan spray pattern. I also tweaked it out between coats with " glitter " by dupli color and the results were amazing. Great stuff. can,t say enough about it. I will be doing my rims with it for sure. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I used it on my Dash with Great results, and I also used there clear coat over the base paint, came out pretty nice. I also used there engine & high temp paints on my motor parts. | | | | | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | I used it on front and rear bumpers and just refinished my wheels. Used clear coat over the top on the bumpers, all came out great.
They also have a high temp engine paint, which I use as I replace parts, gaskets, etc.
Have had great results with all. I would recommend.
Richard 58 3104
| | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | I have used Dupli-Color to paint a car. I painted my Champ silver with Dupli-Color and when I sold it it still looked great. I had it for a little over two years after I painted and it still looked good. I would use it again.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Apr 2006 Posts: 21 Apprentice | | Apprentice Joined: Apr 2006 Posts: 21 | I am painting my 67 with the hugger orange and the gray. The paint goes on nice and shines up good after you spray it with the clear. I plan on putting 4 coats of clear on it when I spray th outside and then I will color sand and buff for a better shine. It is also very easy to fix if you have a problem, like a bug in the paint. MACziggy http://community.webshots.com/user/macziggy4?vhost=community
MACZ
| | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | when you put on glitter do you just add it to the paint and spray it out iv always wanted to try it | | |
