7 members (TooMany2count, 55shaker, klhansen, Phak1, 3800GUY, Gdads51, 1 invisible),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,138 Posts1,056,440 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 1 New Guy | | New Guy Joined: Feb 2008 Posts: 1 | Hello all, I am restoring a 65 C10 long bed, and I was curious what folks thought about sandblasting the panels as a means for removing the old paint and rust. I have heard of sandblasting (possibly improper sandblast technique, not sure) causing the metal to warp. I really don't have any objections towards tackling the whole frame and body with a grinder and paint/rust attachment, but I wanted to get some broad opinions. Any and all opinions and suggestions are welcomed.
Also, in the coming week I'll be on spring break and will gather some pictures to post.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | My opinion: The best method for us lazys is chemical dip. Just make sure the chem is rinsed off well.
~Jim
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | If you use a medium such as glass beads or crushed walnut shells in lieu of sand then less warpage, if any will occur. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | on ,y 49 i did it all by grinder, on my 63 i payed and had it sand blasted. that was 10 times nice, but when you have things blasted, it makes holes wherever the metals is tin, so you will mostly likely put patch panels in places you did't think you would have to. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Also the glass beads, walnut shells, etc. will leave some rust where sand and chemicals won't.
~Jim
| | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Nothing wrong with using the blasting method. Just remember to clean it up as soon as you're finished, and get some primer on it as soon as possible to keep the rust issues to a minimum. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Actually , this is no Bull ...i had my panels sand blasted in mid summer ...just got all of em back from paint ..except the tailgate ...my tailgate has been RAW since mid summer here in the shop ...an has NO SURFACE rust at all ..but my shop is only 3 yrs old ..an well insulated / heated . | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Probably for the same reason our crackers stay fresh at home longer than they did before central air, less moisture in the air.
~Jim
| | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 | We had a 66 Lincoln that instead of sandblasting or bead blasting we had soda blasted.
Worked really well and we didnt have to worry at all about warping any panels. That was a HUGE car and I think it cost about $600 in NY to get the whole car done.
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | I blasted my 50 using a small pressure pot blaster and black beauty for the media. it came out great, just keep your pressure down and dont get to close with the nozzle | | |
