0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
Hello all, I am restoring a 65 C10 long bed, and I was curious what folks thought about sandblasting the panels as a means for removing the old paint and rust. I have heard of sandblasting (possibly improper sandblast technique, not sure) causing the metal to warp. I really don't have any objections towards tackling the whole frame and body with a grinder and paint/rust attachment, but I wanted to get some broad opinions. Any and all opinions and suggestions are welcomed.
Also, in the coming week I'll be on spring break and will gather some pictures to post.
My opinion: The best method for us lazys is chemical dip. Just make sure the chem is rinsed off well.
~Jim
If you use a medium such as glass beads or crushed walnut shells in lieu of sand then less warpage, if any will occur.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
on ,y 49 i did it all by grinder, on my 63 i payed and had it sand blasted. that was 10 times nice, but when you have things blasted, it makes holes wherever the metals is tin, so you will mostly likely put patch panels in places you did't think you would have to.
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
U
U Offline
Do not use sand.
http://www.labour.gov.sk.ca/Default.aspx?DN=d5626a6a-a419-44eb-a5fb-64023263a009
Like olblue posted, use somthing soft for the main strip.
Then load a more agressive mix and go after the problem areas.
http://www.hotrodscustomstuff.com/prostrip.html
Also the glass beads, walnut shells, etc. will leave some rust where sand and chemicals won't.
~Jim
Nothing wrong with using the blasting method. Just remember to clean it up as soon as you're finished, and get some primer on it as soon as possible to keep the rust issues to a minimum.
dj durant
More pix on Flickr
Actually , this is no Bull ...i had my panels sand blasted in mid summer ...just got all of em back from paint ..except the tailgate ...my tailgate has been RAW since mid summer here in the shop ...an has NO SURFACE rust at all ..but my shop is only 3 yrs old ..an well insulated / heated .
1952 Chevy Shortbed
Photos in Photobucket
Probably for the same reason our crackers stay fresh at home longer than they did before central air, less moisture in the air.
~Jim
We had a 66 Lincoln that instead of sandblasting or bead blasting we had soda blasted.
Worked really well and we didnt have to worry at all about warping any panels. That was a HUGE car and I think it cost about $600 in NY to get the whole car done.
SUPPORT OUR TROOPS
"Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan
1966 Fleetside SWB Webshots
I blasted my 50 using a small pressure pot blaster and black beauty for the media. it came out great, just keep your pressure down and dont get to close with the nozzle
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
