| | | Forums66 Topics128,089 Posts1,056,437 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 6 New Guy | | New Guy Joined: Feb 2008 Posts: 6 | hello all. The names Rich and this is my first post.
Truck
Chevy C 10 292 6 cyl 3 on the tree LWB step side
1 What size tire should my tuck have on it? It looks all stock 6 lug 16 inch rim
2 what should the timming be set at?
3 where can i find a maintenance manual for it?
Any help would be great. Thank you
Rich
Stay Cav
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Rich, Welcome to the "Bolt" you didn't say what year your truck is so I would only be guessing on tire size. Timing I would guess at 4-6 degrees BTDC should get you started. Google "Service Manual" for your year truck and you should get several thousand options for buying one! Good luck with your project.
| | | | | Joined: Feb 2008 Posts: 85 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 85 | FYI, You might want to go introduce yourself in the welcome center, but since you are here, welcome! What part of Texas are you in? What year is your truck? Do you have any pics of it? Laterz, Gator >|--|~ | | | | | Joined: Feb 2008 Posts: 6 New Guy | | New Guy Joined: Feb 2008 Posts: 6 | Ops, I can't belive i didnt put that up. Can you tell im a newbie.
Its a 64
And question about that 4-6 Degrees. Thats with the Vacuum advance off and what rpm?
thank you
Rich | | | | | Joined: Feb 2008 Posts: 6 New Guy | | New Guy Joined: Feb 2008 Posts: 6 | wow...getting reply faster then i thought. Ill go take some pics now and put them up. Be right back.
Rich | | | | | Joined: Feb 2008 Posts: 6 New Guy | | New Guy Joined: Feb 2008 Posts: 6 | Okay here goes, lets see if i know how to do it. Sorry its dirty, it just rained. pic 1 pic 2 pic 3 As far as me goes. Im in the army and just got back from Iraq, Im in Killen right outside of Fort Hood.
| | | | | Joined: Feb 2008 Posts: 85 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 85 | Nice truck! I'm fairly positive that those are not the original stock wheels... Someone that actually knows will chime in soon I'm sure. As for you, Welcome back, glad you made it home safe, and thanks for serving! You, and all of our soldiers, have been in my thoughts and prayers and those of all of my family and friends. I have many over seas currently and have lost a few as well. I bounce around Texas a lot (Hot-Shot trucker) but am mainly in San Antonio and way down in McAllen. Laterz, Gator >|--|~ | | | | | Joined: Mar 2006 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 77 | Hi there Rich! Looks like you have a great truck!
I'm pretty sure, too, that those aren't the stock rims. A '63 Chevy that I got the rearend out of had almost the exact same rims, and they weren't stock...
I keep 235/75 r15 tires on my '61. Of course my truck has 15 inch wheels, and the rims are in no way stock, haha! | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Welcome, and thanks. I have a set of those wheels on my 64' and they came from an early 70' Datsun P/U.(just because the price was right,FREE) Good looking truck you've got. I set my timing at 6 degrees without the vacuum, around 700rpm. Just recently installed the Pertronix unit in it, and it's starting and running better now than ever before. | | | | | Joined: Feb 2008 Posts: 6 New Guy | | New Guy Joined: Feb 2008 Posts: 6 | I have been looking for a pertronix unit for my truck. Can you send me the part number for the one you used? Do you have a 292 aswell?
ty ty
Rich
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Definetly not stock wheels. Those were readily availale from just about all of the wheel makers in one form or another over the years, ARE called the the Wagon Wheel, i've seen other names for it too. Nowadays, seems that the only new use for them is for trailers, as thye're not a popular seller for vehicle use. The stock tire size will be 6.70-15, approximatly a 215/75.15 in a modern tire.
Bill Burmeister | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | welcome, nice truck its really clean. 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Rich, Here is the unit number I used for my 230. It's an 1162A Ignitor. You need to make sure your coil is a points style coil with a minimum of 1.5 ohms of resitance, and if you have a ballast resistor in your system, to not remove it. It's a really straightforward install, and when you're done, take your original points plate, put it in the box and put it in the glovebox in case something should go wrong with the new unit. Then all you have to do is reinstall the original setup and your not left on the side of the road. Since I've installed mine, the truck starts better, runs better, and I've noticed the plugs burning cleaner. Here's the number..1-909-599-5955 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2008 Posts: 6 New Guy | | New Guy Joined: Feb 2008 Posts: 6 | I just wanted to say thank you to everyone here...yall are so nice and helpful. Im sure ill be posting here alot.
Once again, thank you very very much
Rich | | | | | Joined: Sep 2007 Posts: 75 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 75 | Richard, the truck looks nice but more important, I'm glad you got back safe. You guys are all heroes and I appreciate each one. | | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | "Okay here goes, lets see if i know how to do it. Sorry its dirty, it just rained."
If that is dirty, sure would like to see it clean...she is pretty! | | |
