| | | Forums66 Topics128,191 Posts1,057,224 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 42 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 42 | This may be offensive ? I want to purchase a reproduction chassis for my son. The builder suggested a Fxxd rearend, with no gear or bearings. I am totally ignorant to anything that is stamped Fxxd, and prejudiced. What G.M differential combination would be an alternative ? 33 Chev coupe, 327, and 66 powerglide, which he may change. I seek help as he lives near Seattle, this is the only help I can offer. Thanks Guys
gene bryson
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | What is Fxxd? Or do you mean FORD? | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If your going to go with ford diff, go with the 9". There's much more aftermarket support for it. Waht the builder is trying to sell you on, though, is an installed bare housing, you'll have to get you're own 3rd member for it. Not really a problem, as that diff is used in almost all customs/hot rods/race cars/every Nascar racer. Unless you have the equipment to do the setup, I'd suggest getting a pre-assembled 3rd member with whatever gear you want to run. I'd also advise a TH700R4 if the car is going to be used on the street, you won't be happy with the 'Glide. One more thing, depending on what front suspension is being used, you'll want to specify that you have matching front and rear bolt patterns on the hubs, not really a big deal. Most likely, the choice will be 5 x 4 1/2", which is the common ford/MoPar pattern. That'll give the widest choice of wheels.
Bill Burmeister | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | The Ford 9" is a great rear end for sure the best GM alternative would be a car 12bolt a Mopar 8 3/4" would also be a good choice. The 9" ford is your best bet though. Scribner Welding in Kent WA. if I could find his card I would give you the number but look him up very good and reasonable at building custom rear ends. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Oh here you go I didn't know he had a web site. http://scribnerwelding.net/ | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I would go with a Moser rear diff. You send them your measurements and what gear ratio, width and bolt pattern, brake style and they send you a diff that fits like a glove. It's a Ford 9" style but much beefier, Scott | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't recal who makes it, but ther's one out called the 9+. basically, it's a ford 9" housing with Chevy 12 bolt guts. Seems that the gear from the 12 bolt is actually stronger due to the better location of the pinion in relation to the ring gear.
Bill Burmeister | | | | | Joined: Jun 2007 Posts: 42 'Bolter | | 'Bolter Joined: Jun 2007 Posts: 42 | Thanks Fellas I appreciate the response, sometimes even adult children don't listen. I wish there was a resource like this site when I was young! Again Thanks I may (will) call on you again
gene bryson
| | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | theres nothing wrong with a good power glide with a shift kit and big motor when it shifts you know it and there realy fast all they do is shift twice iv been in some fast cars that have been blowen away buy the power glide and on top end also | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 'Glide will be fine, as long as the rear is geared right. And 'Glides only shift once, hi gear is 1:1. However, if this car is going to see highway use and regular driving, a trans with an overdrive will be much more pleasureable at highway speeds.
