5 members (Millenimech, dwreills, RdsLessTaken, Otto Skorzeny, 1 invisible), 87 guests, and 3 robots.
Topics128,036
Posts1,055,461
Members48,422
#358488 01/09/2008 5:06 PM
What's the biggest improvement you have made to your truck. Could be anything. Run better, ride smoother, look better, more fun, you get the idea.
Here's mine:
'57 235
Radial tires
T5 transmission
Hopefully, Carter/Weber carbs (still working on that one)
What have you folks done?
George
My truck is far from being completed, but I would have to say replacing the rusted sheetmetal on the cab was the biggest improvement for me.
My biggest improvement was installing the M2 frontend with power rack and pinion steering.The second biggest was the 350 Chevy V/8 and 700R4 trans.The truck now will run down the freeway at decent speeds and handles like a new truck.
M11 front suspension
ZZ4 350 engine
700R4 tranny
New paint job
Power disc brakes
The biggest improvement I made to my truck when it had the 235 in it was probably the swap of the original 1bbl Rochester carb with a 2 bbl Holley/Webber carb. I picked up power and torque, and my mileage improved too.
The next biggest improvement was with a change from points to Pertronix electronic ignition. Always started on a dime and ran perfectly. Well worth $70.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
4.10 instead of 5.14 in the diff. There is far more of a difference than the numbers imply.
1951 3800
-hotshoe
I see you've already done this, but the radial tires and O.D. are the top 2 on my list. I've also added dual exhaust, HEI, new shocks, a full gauge instrument panel, and dynomat to the floor. Next will be front disc brakes and rear drum rebuild, complete suspension rebuild (stock) and finally the addition of my 261 stroker. I will also be replacing the bed and cab mounts.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Power steering to replace the worn out steering box. The truck already had a 350, auto, and a/c when I got it. Next will be some supension work and disc brakes, then some rust repair panels/
Rebuilding the engine. Updated with Fenton Exhaust, Edelbrock 2x1 intake, bored .040 over and domed pistons my machinist had lying around. Total new found power and acceleration. Soon I will install my 3sp+ OD.
58' 3200 235 3-speed/OD
I got it running grin
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
Apprentice
Apprentice
1. MII front suspension, by far the biggest improvement. Followed by these as #2;
Power rack n pinion steering
Power disk brakes all around
4" dropped leaf kit in rear
SBC power
6/6 slam to the pavement
More to follow!
No question - the T-5 transmission I put in this past year! It was like the frosting on the cake.
Joe grin
steerability baby
just as sweet and tight as can be
http://www.stovebolt.com/techtips/draglink_adjustable.html
and
the 12 bolt 3.40:1 rear end
292 e/w hei, edelbrook 5
Hybrid-T5
disc
paint job
she loves them danceheated seats grin wink
Jim & Caroline
Getting rid of the mouse stink....the popularity level rose significantly with the family after that.
Re-doing the interior would probably be a more accurate answer to the question.
ODSS Lawman
ODSS Lawman
For me, it was the radial tires, and 3:55 gears.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
