1 members (Peggy M), 95 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
#35721 11/18/2004 10:29 PM
Apprentice
Apprentice
Hey Guys, I just bought a new gas tank for my 1950 1/2 ton from Yogis. It is manufactured by Tanks Inc. and only cost $225 (universal pick-up steel gas tank). It was the best deal I could find and I must say it is very nice.
Anyway, I'm thinking of sealing it before I install it on my truck. Does anyone know of a good product to seal gas tanks? Thanks for your help.
Everything you know is wrong.
#35722 11/18/2004 11:34 PM
Why seal it? You just put up $225, is there a reason for concern? Do you want to seal the outside or the inside or both?
#35723 11/19/2004 12:29 AM
Apprentice
Apprentice
Well, I plan on keeping it for many, many years. My thoughts are an ounce of prevention beats a pound of cure. Plus it is recommended by the manufacture.
I will probably seal the inside and paint the outside. I may not even worry about it depending on the cost of sealer. Any recommendation on sealer?
#35724 11/19/2004 12:58 AM
sbigelow. i am with phatboy why seal, stainless will last for years. but if you must go to eastwood.com that way you can check on line and save some running around. most logal parts house will haveit, napa, auto zone advance auto, what ever is in your area. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#35725 11/19/2004 1:04 AM
Apprentice
Apprentice
Problem is it is not stainless steel. Good old regular steel. I will check Eastwood. Thanks.
#35726 11/19/2004 3:11 AM
Don't seal it. Over time, gas will break down the sealer and it will end up in your carb. To prevent internal corrosion and rusting, keep the tank full of gas. Since it's going to be a new tank, use ethenol, it helps with moisture. Also, make sure you have a drain in the bottom of your tank for removing old gas if it gets stored for long periods of time.
Just my 2 cents,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#35727 11/19/2004 7:13 AM
The inside of your new tank will last about 50 years "as it is".
Painting the outside would look nice and protect it from the elements.
47 Fleetmaster, Hotrod 6, 5 Speed
50 Sedan Delivery, 327, 5 Speed
#35728 11/19/2004 9:42 PM
Riding in the Passing Lane
I agree. Dont seal the inside. If that stuff
starts flakeing off you have a real problem. smile
1972 Chevy c10 Cheyenne Super
#35729 11/19/2004 9:47 PM
Plus, if you seal it and then have a problem, you may not have a warranty.
1951 1 Ton Completed
#35730 11/20/2004 1:53 AM
Prime and Ryhno the outside and then paint your color choice over that. Best protection!! Do not seal the inside. As all said flaking starts then you have to throw tank away. popcorn The Truth is Out There (I bought 16 gal Race tank from Summit foam filled and has GM OHM unit, cut a little off back frame install, plumb ready to go)Ben
#35731 11/20/2004 4:13 AM
I am not pleased with the por 15 sealer. I took the old tank out 5 years ago and cleaned it per the directions.
#1 it sealed over the exhaust pipe and pumping gas is slow. (something I can fix but not a priority).
#2 5 years later I'm getting rusty gas and changing filters every couple of weeks.
I plan on buying the chevy duty replacement tank for may 54 for $139.00 and just painting the outside.
I vote no sealer.
53 3100
1929 Ford Roadster Pickup
1934 Ford Pickup
68 Plymouth Satellite RR Clone 2 Door
My Fleet
#35732 11/21/2004 2:52 AM
Apprentice
Apprentice
Thanks for the advice. Looks like sealing is not the way to go.
