0 members (),
192
0
Mod | | | Forums66 Topics128,089 Posts1,056,143 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35721 11/18/2004 10:29 PM | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | Hey Guys, I just bought a new gas tank for my 1950 1/2 ton from Yogis. It is manufactured by Tanks Inc. and only cost $225 (universal pick-up steel gas tank). It was the best deal I could find and I must say it is very nice. Anyway, I'm thinking of sealing it before I install it on my truck. Does anyone know of a good product to seal gas tanks? Thanks for your help.
Everything you know is wrong.
#35722 11/18/2004 11:34 PM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Why seal it? You just put up $225, is there a reason for concern? Do you want to seal the outside or the inside or both? | | |
#35723 11/19/2004 12:29 AM | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | Well, I plan on keeping it for many, many years. My thoughts are an ounce of prevention beats a pound of cure. Plus it is recommended by the manufacture.
I will probably seal the inside and paint the outside. I may not even worry about it depending on the cost of sealer. Any recommendation on sealer?
#35724 11/19/2004 12:58 AM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | sbigelow. i am with phatboy why seal, stainless will last for years. but if you must go to eastwood.com that way you can check on line and save some running around. most logal parts house will haveit, napa, auto zone advance auto, what ever is in your area. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#35725 11/19/2004 1:04 AM | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | Problem is it is not stainless steel. Good old regular steel. I will check Eastwood. Thanks.
#35726 11/19/2004 3:11 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Don't seal it. Over time, gas will break down the sealer and it will end up in your carb. To prevent internal corrosion and rusting, keep the tank full of gas. Since it's going to be a new tank, use ethenol, it helps with moisture. Also, make sure you have a drain in the bottom of your tank for removing old gas if it gets stored for long periods of time. Just my 2 cents, Scott | | |
#35727 11/19/2004 7:13 AM | Joined: May 2004 Posts: 62 Member | | Member Joined: May 2004 Posts: 62 | The inside of your new tank will last about 50 years "as it is".
Painting the outside would look nice and protect it from the elements.
47 Fleetmaster, Hotrod 6, 5 Speed 50 Sedan Delivery, 327, 5 Speed
#35728 11/19/2004 9:42 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree. Dont seal the inside. If that stuff starts flakeing off you have a real problem.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#35729 11/19/2004 9:47 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Plus, if you seal it and then have a problem, you may not have a warranty. | | |
#35730 11/20/2004 1:53 AM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Prime and Ryhno the outside and then paint your color choice over that. Best protection!! Do not seal the inside. As all said flaking starts then you have to throw tank away. popcorn The Truth is Out There (I bought 16 gal Race tank from Summit foam filled and has GM OHM unit, cut a little off back frame install, plumb ready to go)Ben | | |
#35731 11/20/2004 4:13 AM | Joined: Apr 2001 Posts: 162 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 162 | I am not pleased with the por 15 sealer. I took the old tank out 5 years ago and cleaned it per the directions.
#1 it sealed over the exhaust pipe and pumping gas is slow. (something I can fix but not a priority).
#2 5 years later I'm getting rusty gas and changing filters every couple of weeks.
I plan on buying the chevy duty replacement tank for may 54 for $139.00 and just painting the outside.
I vote no sealer.
53 3100 1929 Ford Roadster Pickup 1934 Ford Pickup 68 Plymouth Satellite RR Clone 2 Door My Fleet
#35732 11/21/2004 2:52 AM | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | Thanks for the advice. Looks like sealing is not the way to go.
