6 members (Bill Hanlon, Leo, GMCJammer51, Phak1, Tom McGrath, dt235sd), 105 guests, and 2 robots.
Topics128,050
Posts1,055,646
#351045 12/21/2007 1:10 PM
Just checking my sanity here, would a backfire thru the carb be timing? and it only happens under load on occassion.
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
A little hard starting is it? Ya got the timing advanced to fur! use a timing light and set it where the factory spec say to set it.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
could be an exhaust valve sticking. i have found that an old engine
will build up crud on the valve stems at heavy load they tend to open just a little further than at idle and stick for a fraction
of a second. i would pull the cover rotate the exhaust valves
open one at a time and tap them (not frail )with a hammer they
should have a live hollow sound and the hammer will bounce.
if they sound dead they are sticking some good pb blaster and a little taping will free them up if they aint bent
Is it a backfire (loud bang), or like a cough with a hesitation?
If it like the latter, it could be a too lean fuel mixture.
Builder;
It does the latter, a cough, engine starts right up. The Rocjester B was rebuilt and does not leak (yet) and the accelertor pump gives a good shot down the carb and the heat flapper valve works correctly. I am wondering if the #1 or #6 cylinder get a little lean on occasion
BIG difference between "backfire thru the carb" and a cough or hesitation. I've been going thru the later with my stock 1950, 216 with a 'B'. The general consensus seems to be running the engine to cold, especially since the weather has turned on us. I have a 160° stat in there now and the suggestion is that I run a 196° and see if the stops the hesitation, I haven't gotten around to it yet.
Philip, if it were a stuck, burnt or carboned up valve a backfire thru the car would present itself all the time, not just "it only happens under load on occasion". That would indicate timing. A hesitation or cough as xx re-described would most likely be a fuel problem.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
mine was popping and backfiring thru carb. turned out i hadn't properly retightened rockerarm assembly after replacing bent push rod due to stuck valve. it took some running for it to work loose but was immediately obvious when i removed the valve cover.
it was only doing it occasionally at first got worse as the bolts loosened up.
kb3csw #352519 12/25/2007 10:35 PM
try replacing your condenser, and when you charge your battery disconect your battery cables
1949 SUBURBAN
