| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | Just checking my sanity here, would a backfire thru the carb be timing? and it only happens under load on occassion. 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A little hard starting is it? Ya got the timing advanced to fur! use a timing light and set it where the factory spec say to set it. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | could be an exhaust valve sticking. i have found that an old engine will build up crud on the valve stems at heavy load they tend to open just a little further than at idle and stick for a fraction of a second. i would pull the cover rotate the exhaust valves open one at a time and tap them (not frail )with a hammer they should have a live hollow sound and the hammer will bounce. if they sound dead they are sticking some good pb blaster and a little taping will free them up if they aint bent | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Is it a backfire (loud bang), or like a cough with a hesitation? If it like the latter, it could be a too lean fuel mixture. | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | Builder; It does the latter, a cough, engine starts right up. The Rocjester B was rebuilt and does not leak (yet) and the accelertor pump gives a good shot down the carb and the heat flapper valve works correctly. I am wondering if the #1 or #6 cylinder get a little lean on occasion 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | BIG difference between "backfire thru the carb" and a cough or hesitation. I've been going thru the later with my stock 1950, 216 with a 'B'. The general consensus seems to be running the engine to cold, especially since the weather has turned on us. I have a 160° stat in there now and the suggestion is that I run a 196° and see if the stops the hesitation, I haven't gotten around to it yet. Philip, if it were a stuck, burnt or carboned up valve a backfire thru the car would present itself all the time, not just "it only happens under load on occasion". That would indicate timing. A hesitation or cough as xx re-described would most likely be a fuel problem. Denny Graham Sandwich, IL
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | mine was popping and backfiring thru carb. turned out i hadn't properly retightened rockerarm assembly after replacing bent push rod due to stuck valve. it took some running for it to work loose but was immediately obvious when i removed the valve cover. it was only doing it occasionally at first got worse as the bolts loosened up.
| | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | try replacing your condenser, and when you charge your battery disconect your battery cables | | |
