| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34700 05/21/2004 5:23 PM | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | I realize I could just call an auto parts store but wanted to get your ideas on replacing the shocks on my 1950 1/2 ton. Can you buy them at a NAPA or do you have to go through ChevyDuty or other classic vendor? Just want to put fresh shock on but don't need to be original to be happy. What have you all done? | | |
#34701 05/21/2004 5:28 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | GoCougs: jeesh you sports guys I order mine from ChevyDuty, but, I think somebody around here said they got theirs from napa. popcorn The Truth is Out There (GOIU) | | |
#34702 05/21/2004 6:53 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Gabriel makes both front and rear shocks for the 1/2 ton, any store should have them in stock or order them. I got mine at autozone.
#34703 05/21/2004 10:48 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Napa:
Front # 5826 Rear # 20803
This is what I have on my '50
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#34704 05/24/2004 5:36 AM | Joined: Mar 2004 Posts: 83 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 83 | Speaking of shocks, has any one used the aftermarket bracket kits from Chevy Duty and the like for putting tube shocks on their old knee-action shocked Chevies? Or does anyone have a spare set of original 50's brackets so I can update my 48 Chevy to tube shocks? I have been daily driving it with wore out knee-action shocks for only about 20 yrs (off and on), so figure it was about time to get "real" shocks on the little ole' '48. Thanks, Garry
Garry K in Pac Nor West 1948 Chevy PU 235 SM420 4 spd 1932 **** B pu 1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
#34705 05/25/2004 5:27 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I found a set of shock brackets from a 53 to replace the lever shocks on my 49. I measured the position for the front mounts from another 53 and bolted them on using Grade 8 bolts. However I still have not mounted the rear brackets and wonder how critical the angle should be. | | |
#34706 05/25/2004 8:18 PM | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | Thanks for the info. NAPA changed the number for the rear shocks to #94004 and they were $11.90 each. Best part is that they have 2 in stock at my local store. Now the task of removing the old original ones. | | |
#34707 05/25/2004 10:01 PM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | I got mine at auto Zone. I think they were $13. Lifetime warranty. Gas shocks. | | |
#34708 05/26/2004 3:51 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | Buffalo has tube shock kits for the early trucks. Heavy duty fabbed by the Buffalo, N.W. Washington.  | | |
