3 members (Guitplayer, baldeagle, MickeyP), 104 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#34700 05/21/2004 5:23 PM
I realize I could just call an auto parts store but wanted to get your ideas on replacing the shocks on my 1950 1/2 ton. Can you buy them at a NAPA or do you have to go through ChevyDuty or other classic vendor? Just want to put fresh shock on but don't need to be original to be happy. What have you all done?
#34701 05/21/2004 5:28 PM
GoCougs: jeesh you sports guys I order mine from ChevyDuty, but, I think somebody around here said they got theirs from napa. popcorn The Truth is Out There (GOIU)
#34702 05/21/2004 6:53 PM
Gabriel makes both front and rear shocks for the 1/2 ton, any store should have them in stock or order them. I got mine at autozone.
Paint & Body Shop moderator
#34703 05/21/2004 10:48 PM
Napa:
Front # 5826
Rear # 20803
This is what I have on my '50
Craig
#34704 05/24/2004 5:36 AM
Speaking of shocks, has any one used the aftermarket bracket kits from Chevy Duty and the like for putting tube shocks on their old knee-action shocked Chevies? Or does anyone have a spare set of original 50's brackets so I can update my 48 Chevy to tube shocks? I have been daily driving it with wore out knee-action shocks for only about 20 yrs (off and on), so figure it was about time to get "real" shocks on the little ole' '48.
Thanks, Garry
Garry K in Pac Nor West
1948 Chevy PU 235 SM420 4 spd
1932 **** B pu
1964 Datsun 4x4 with SBC, SM465 4spd and Rockwell xfer Dana 44Fr and 12 Bolt Rr.
#34705 05/25/2004 5:27 AM
I found a set of shock brackets from a 53 to replace the lever shocks on my 49. I measured the position for the front mounts from another 53 and bolted them on using Grade 8 bolts. However I still have not mounted the rear brackets and wonder how critical the angle should be.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#34706 05/25/2004 8:18 PM
Thanks for the info. NAPA changed the number for the rear shocks to #94004 and they were $11.90 each. Best part is that they have 2 in stock at my local store. Now the task of removing the old original ones.
#34707 05/25/2004 10:01 PM
I got mine at auto Zone. I think they were $13. Lifetime warranty. Gas shocks.
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#34708 05/26/2004 3:51 AM
Buffalo has tube shock kits for the early trucks. Heavy duty fabbed by the Buffalo, N.W. Washington. grin
