1 members (Lightholder's Dad), 66 guests, and 3 robots.
Topics128,142
Posts1,056,491
Members48,442
#344260 12/03/2007 4:24 PM
I have a '53 3/4 ton that has the 216 in it. The engine is shot and a friend gave me a 292. After doing some checking and thinking I decided not to use the 292. It is on ebay now and I have been offered a 230 in trade. Does anybody know anything about the 230, cause I don't. What would be the chance it would drop in to replace the 216?
Derek
Zero, the 194,230,250,292 all use different motor mounts, transmissions & mounts, driveline, etc... You will have to make or buy everything, nothing will interchange with the older 216,235's. Joe
A 230 is a different engine altogether. You'll need to change bell housings, make engine mounts, convert to 12 volts etc. A direct swap will be a 235 or a 261,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks for the quick replys. Sounds like I would be in the same boat then with the 292. I will keep looking for a 235 or 261.
Thanks again.
Derek
Flexjet cant come up with the engine on ebay. Please post the number. Thanks
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
Been looking on ebay and found a 235, the guy won't ship though and I'm not going to New Jersey to pick it up. If anybody knows where one is in the South Texas area is, I can do that. My number is 361 571 2496 or [email protected]
Got a 54 235 big truck engine in mid Iowa. Road trip?
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
I have a 235 in Colorado I'd sell you out of my truck (daily driver). At least I think it is a 235. How do I tell a 216 from a 235? Do all the 216's have the two "acorn" nuts on top of the valve cover? The 235's have the four bolts on the edge...?
1953 Chevy 1/2-Ton 3100 5-Window
1937 Chevy 1/2-Ton
1970 Chevelle
Easiest way to tell them apart is the valve side cover. It is all the way up around the spark plugs on a 216 and only aboyt 5-6" tall on a 235. And also the 216 did use two center valve cover studs and nuts but adaptors are sometimes used to keep that look on later 235 engines as when an Offy aluminum cover is used. Mine is that way so the valve cover check is not always correct unless you know the rest of the story.
Not nearly as confusing as it sounds once you get the hang of it.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
