2 members (NJC, greenie-reddy),
159
Mod | | | Forums66 Topics128,260 Posts1,058,287 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I'm looking for some suggestions to clean old glass. My 43 year old windows have a cloudy film that Windex can't touch. Are there some better products or methods that will do better? Thanks for any advice.
Jeff
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Jeff - All of the windows in my '41 were in pretty bad shape; either cloudy or delaminated to the point at which the glue was visible. There were also some DA scratches in the glass from sometime in the distant pass.
Although it wasn't in my original plans I ended up renewing all of the glass because other than not being able to see too well out of it the condition distracted from the rest of the restoration.
Good luck,
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | Is it the glass or the plastic between the glass that's hazy? Other than etching or similar process I've never heard of glass becoming hazy. If it IS the glass you might try using jewler's rouge with a soft terry cloth over a random orbital sander pad & try buffing the haze out of it. Glass is hard so it might take some effort to get it right. If it's just a coating of some kind that windex won't touch use Bon Ami oven cleaner to clean the glass. It'll put windex to shame on any glass window.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Jewelers Rouge is available at places like Wal-Mart I think or you could ask someone at an actual jewelers. It will take out the imperfections and clean without scratching. There is also a batting cloth for cleaning wheels that they sell at places like Checkers or Pep-boys (sorry don't remember the exact name). I used this on similar film on my 1950 and it cleaned up my side windows perfectly. The others were broken so I had to replace them. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jeff,
If it is actually something ON the glass, I wonder if it could be deposits from hard water. I have used Lime-Away to remove mineral deposits on glass and it was amazing.
Stuart | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Give onna them MAGIC ERASERS a try ...they work wonders on all kinda stuff ...Ive had very good luck on fiberglass and such | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I haven't seen the Magic Erasers but I'll look. A guy at the local paint supply store suggested that I scrape it with a razor blade. I tried that last night and it helped a lot. They're clean enough now that I can see some scuffs and scratches. I've got a glass scratch repair kit from Eastwood that I'm going to try now. Does anyone have any experience with that stuff?
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Window Glass Polishing Compound??? Many years ago, in fact about 1966 I was stationed in Sacramento, CA with the USAF. One night while I was in a red neck bar some good old boys pitched an Oly’ beer bottle through the back window of my ’60 Biscayne. I picked up a window at the junkyard the next day and took it to a glass shop to have it installed. After he got it in he took a 6” buffer to it and polished it up, saying that it took out all those little scratches they pick up in normal use on the roadway. A long time ago but I thought he said that the compound was Pumice. Has anyone else ever heard of this?? Haven’t heard from Wilber for a long time, I’ll bet he would have an answer since he owns a glass shop. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | I'm not sure what the abrasive is in jewler's rouge. Chrome polish would probably work OK too. It's just a real fine grit in a solution.
| | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Eastwood sells a compound and a wheel for cleaning and polishing glass. I haven't used it but at some point I will for my windshield. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Years ago when my dad ran a service station for a spell he would have folks pour coca-cola on them and the coke would cut the grime right off. I have personally used this many years ago and it will definately cut most of the "regular" dirt off when nothing else would. Just adding info to the line. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | four ought steel wool(oooo) works very good on glass and mirrors and will not harm glass.i use it all the time to remove overspray and funk off of em...........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Have used the Eastwood kit. Polishes glass very well unless scratches are deep enough to catch your finger nail. Just mask off your work area so you don't splatter your paint or get it down inside your window tracks. Make sure it is plenty moist when you mix up the solution, make sure the pad has been soaked, and put plenty on as you work the area. It takes awhile but I've been happy with the results. | | | | | Joined: Oct 2006 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 128 | Be careful with the "polishing kits"... if you work it too much you'll start driving along and swear you put on your nearsighted cousin's glasses. These kits can cut into the glass just as if someone were grinding a pair of prescription glasses. I've been in one vehicle where the owner was proud of the polishing job he did. Sure the glass was perfectly smooth but I think if I had been in the vehicle for more than 10 minutes I would have had a headache and I couldn't imagine riding in it at night against oncoming traffic. I think he replaced the glass the next weekend. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | If the haze is caused by teh laminate between the glass along the edges. They tell me soaking a rag in Ever-clear 200 proof alkahol, will sometimes saturate the plastic and clear it up. I have a front window that is like that and I will give it a try.
Besides I always wanted to sip some Ever-clear. | | |
