| | | Forums66 Topics128,089 Posts1,055,991 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Hi Guys,
Kinda Stovebolt related here. Got the Blazer plow truck out of the shed today. Opened the door and about fell over....MOUSE stink. I've taken the heater core and heater box, ducts ect all out. Anyone have any good home brews to help get the stench outta the inside? I'm going to replace the heater core and have washed the heater housing and ducts with pine sol and water. Got the truck sitting outside to air out now. Thanks, Don
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | The main thing is to be sure and get all of the mouse nest out. Many times, if the smell continues to linger, it means that there is still some nest material in there somewhere. Otherwise, it's like you said, wash it up, and air it out. When I put my stuff away for the winter, I put a bar of Irish Spring soap in there. Supposedly, the mice don't like it. Also, it leaves a better aroma than moth balls. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Since the mice have already been in there, your pretty much SOL. If the are limited to the HVAC assembly, you can try a few drops of hand soap in a bucket of hydrogen peroxide with a little baking soda added. I think the ratio is 32 oz of H2O2, 1 table spoon of baking soda, and 4-5 drops of hand soap. (it is supposed to work on dog urine) If they got into the carpet, padding, seats, etc. there is no simple method short of completely removing the interior and replacing. The uric acid is what gives off the smell, and it permeates the pores in the paint as well as plastic, etc. You can rent an ozone machine and try that, some people have had luck, others have not. If they got into the headliner, remove the headliner and discard.
I also recommend the scented soap. I usually grab the stuff out of the bathroom and make Margaret buy more from the house. I use the soap for storing anything as the scent keeps mice and spiders out of the cars, boat, etc. A few well placed pieces in a disposable dish works wonders.
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Id probably try bleach if youve got parts that it wont effect. Air it out good.
I found nests all over mine and it probably took me about 6 months to find them all. They were in the headliner, glovebox, seat, inside the door hinges, etc...
Took another 6 months for most of the smell to finally go away.
Good luck, Jeff | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | This is what I have done in the past. It is not something your wife would approve of but, take a pump-up sprayer and fill it with diesel. Pump it up and spray anything, everything, and anywhere that rat has been. It will take a while for the diesel smell to disapate but better to smell diesel than rat doodoo.
~Jim
| | | | | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | Just a safety note. Make sure you're wearing rubber or vinyl gloves when handling anything realted to mouse or rat crap. A resperator mask as well. Hantavirus (sp) apperently isn't fun to get.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
| | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | this will work get a ionizer the big kind for houses i have two put it in the truck on high with windows up for a few days this works to kill mold and smells also | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | bleach water w/some Dawn as well, they like to get above the windshield of these trucks, if ya don't clean it out it will still stink | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | What Joe maybe referring to is "Odor & Stain Eater" by Unique Mfg. and Mrkting, Arvada, CO. The garage where I'm at now was previously occupied by dog owner who didn't bother to take care of his dogs. It smelled bad even two years after he was gone. I picked this product up at the local ACE and two weeks after mopping it down on the cement floor the odor was gone. It's even suppose to be good for skunk odor and has a money back guarantee. I called them several times for advice and they were real helpful.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Depending on the condition of the truck, I have taken out all the seats, carpets and clean the cab corners out and have actually pressure washed the cabs out. Wash with bleach water after that. I try to not handle as much of that crap as possible. When it drys, I use some odor remover from Kameapart or WallyWorld and spray down everything. The seats I will wipe down and bang around to get as much dust, crap, etc out of it. Usually the seats are crap anyway, so I don't worry about ruining them. I spray the seats a couple of times with the same odor stuff. It usually does the trick. I use Irish Spring to store them.
One place the mice get is in the headliner above the windshield. Usaully it ends up rotting the metal above the windshield from the mouse urine. That is a hard place to clean out. | | |
