8 members (mvigo, Charles in CA, Rusted Nut, UtahYork, Peggy M, Shade Baby, klhansen, 1 invisible), 80 guests, and 2 robots.
Topics128,074
Posts1,055,913
Members48,429
#334698 11/08/2007 12:43 PM
I'm gonna take my frame to the local car wash next week to clean off the grease and grime. Was gonna do it at home, but I don't trust my well right now do to lack of rain, plus the car wash is heated. Anyway...I got most of the thick buildup scraped off and was wondering what is the best degreaser to use to help loosen the rest of the grease? Would a typical oven cleaner do the job?
Thanks in advance!
2 Offline
Yes the oven cleaner is a good tool to get the grime off. I usually buy the store brand, it is cheaper than the name brands. I also use mineral spirits and a kerosene mix to get the grease off.
I have used Easy Off (heavy duty or something I believe) oven cleaner quite a few times with good luck. I just spray it on liberally and let it soak for a few hours then take it to the car wash. The combination of the cleaner and high pressure water will typically take almost all of the grease off if you spend enough time. It will also take off the factory paint on the frame and inner fenders, so keep that in mind if there are areas you do not want the paint to come off. Of all the methods I have tried, this seems to be the quickest and easiest.
I personally like & use Castrol Superclean ..in the gallon purple jug you can pick up at any Walmart ...It is good stuff !
1952 Chevy Shortbed
Photos in Photobucket
I use "Greased Lightning" in a purple bottle. Works great. Not flammable, and easy on your skin.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
I use have used kerosene for degreasing for years.
Commercial floor wax remover will do a great job. You can buy it in the Gal jug at Home Depot. It is not as strong as some commercial grades but will work.
~Jim
Ron, I swear by Westley's Bleche Wite
I had some brake backing plates on my jeep that had about a half inch of 60 year old petrified crap stuck to them.
Someone at the jeep web site recomended this stuff. They said it was the strongest cleaner you can buy withour a license.
Not only did it clean off the crap with very little elbowgrease, but it removed half the old paint.
You can buy a spray bottle for a couple of bucks and give it a try. It is very caustic, so wear rubber gloves. And, it will curl your nosehairs, so use it outdoors. Don't bring your chassis into the living room.
"Happiness equals reality minus expectations" - Tom Magliozzi
Super clean in the purple gallon, very good stuff, used to be made4 by Castrol but I think they sold it off, anyway, very very good cleaner, wear rubber gloves, and eye protection, pretty caustic stuff.
Birge
1952 Cheverolet 3600
http://www.flickr.com/photos/bilge77/
Gotta agree with oven cleaner. Lemony fresh scent, and you can just hose it off. I've found it works better than Gunk degreaser.
Dawn dish soap works great. Spray it on or squirt it on straight from the bottle, let it soak (the longer the better)and then power it off at the car wash. Best price of anything you'll find out there to try.
DJ
dj durant
More pix on Flickr
Tramp #335557 11/10/2007 12:13 PM
What’s the matter with plain old “Gunk Engine Bright” in the spray cans or in bulk? It’s been around for a hundred years and is made for doing just that and it's available everywhere, F&F, TSC, Auto Parts, Hardware Stores, etc.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Apprentice
Apprentice
HELP!!!!!!I JUST BOUGHT A 58 APACHE TRUCK ... STOCK FRAME.. NO MOTOR .. NO TRANS... I HAVE A 454 BIG BLOCK CHEVY TO PUT IN....THE FRAME RAILS ARE TOO WIDE.... ANY SUGGESTIONS?? I NEED HELP...
gina #336602 11/13/2007 2:30 AM
A couple of suggestions. First, take your cap lock off. Second start a new thread with your question in the "Hipo" forum. You'll get better response there.
Welcome to Stovebolt.com
Apprentice
Apprentice
I like the "purple power" stuff. Cheap, it works and it isn't so caustic and toxic. Someone else mentioned a purple cleaner that they said was caustic. We must be thinking of different cleaners. You can use "purple power" to wash your hands if you need to.
1966 C10 Fleet
webshots
Well...I went to the FLAPS near me and get this...THEY NEVER HEARD OF CASTROL SUPER CLEAN! I couldn't believe my ears. Then it dawned on me...I have some orange citric parts cleaner solution from SAFETY KLEEN in a 6 gallon bucket that has never been opened. WOW...I scored! I've been spraying the entire frame every day for the past (4) days now, scraping the big stuff off as I go. A friend of mine is coming over with his trailer on Wednesday to help me take it to the car wash. I have a choice though...use his pressure washer @ 3500 psi using cold water or take it to the car wash using hot water wit soap @ 1200 psi. Any recommendations which way to go?
I really can't wait to start on this frame. To me, Wednesday is a big day for me!
Do both. Pressure wash first ,then to the car wash. Spray it down with WD-40 or it will rust before your eyes.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
