11 members (Woodcmiami, tonyt, DannyW, Bill Hanlon, walter74, gswbbc, baldeagle, lumbersawyer, Otto Skorzeny, JW51, 1 invisible),
86
Mod | | | Forums66 Topics128,040 Posts1,055,475 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 8 New Guy | | New Guy Joined: Feb 2005 Posts: 8 | Anybody out there have any problems with wind noise from the doors on a 55-59? I have installed new door rubber and the doors are aligned great. Driving around town is not a problem. It's when I hit the highway when it gets loud. It is difficult to listen to the stereo or have a conversation. Anybody have any cures?  | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | If your doors are all sealed up and you know it's not that, then it must be your windows need new felt channels.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | go around the door seals with a dollar bill if you can remove the bill easy when shut adj in,,if window noise ,,is felt good if good look at stops also where is crank located when window is closed...doc | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Doc
What do you mean when you say where is crank located when window is closed ... how does the crank position effect anything?
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Feb 2006 Posts: 346 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 346 | Your right Alan, the crank postion has nothing to do with anything.
Terry K.
27 Chevy Capitol 1 Ton
Terry K.
1951 5 window 1/2 ton
The only way to have a friend is to be one. -Ralph Waldo Emerson-
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It does if the window tends to fall back down. With the weight of the crank pulling down on the regulator, which rolls the window up, then the window will stay up. If the weight of the crank is the other way (180 degrees), it will allow the window to work it's way down as you drive along. Some windows are too tight or stiff for this to matter but I had a 64 that would roll itself down because of this. Scott | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Scott's right. I've seen that happen before.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Feb 2005 Posts: 8 New Guy | | New Guy Joined: Feb 2005 Posts: 8 | Thanks for the tips guys. I have new felts in the windows as well as new door rubber. The windows seal up nice and the glass doesn't giggle down on a bumpy road. I can see daylight out the top of both doors. The dollar bill trick won't work there but a catalogue might. I get a good seal on the rest of the door, it's just the top. The doors are aligned nice and close great. Perhaps the door tops need to be bent in a bit. | | | | | Joined: Feb 2006 Posts: 346 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 346 | Scott, Good point, Thanks for the info. Never gave it a thought before. I would have guessed the felt and new door rubber would have been enough to keep the glass up.
Terry K.
Terry K.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | sometimes the top part does need "pulled in". I once had to put my knee against the inside panel and pull the top part of the frame in towards the cab. Solved a lot of my wind problems. | | | | | Joined: Feb 2005 Posts: 8 New Guy | | New Guy Joined: Feb 2005 Posts: 8 | I did the dollar bill trick like Doc suggested and I have a great seal around the doors except at the sharp curves at the top of the door above the vent window and also just in front of the vent window. It is only at these sharp curved areas and I can probably manipulate the rubber to close it up. Someone suggested useing pieces of windshield washer hose to shim the weatherstripping. I haven't done it yet but sounds like a solution. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I heard a guy say once that he put a 2x4 in the bottom of the door ... closed the door against it and pushed on the top of the door. It worked for him.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | Achipmunk is absolutely correct. I too have done the knee into the center of the inside of the door trick and bent the top inward with everything I had. It is amazing just how much it tightened the gap above the wing window.
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
