7 members (Forty9, fonz8261, jkreiner, treegrower, Bill Hanlon, Wally / Montana, TexasJim50),
51
0
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 40 |  My window on my 62 C60 is stuck about 3/4 of the way down. I want to get it closed to keep the weather out. I tried to roll it up tonight and broke the short metal brace from the regulator to the main braces :o I got the inner cover off and sprayed things with WD-40, you guessed it I dropped the can and I can't reach it  Any ideas on how to solve these problems? Thanks | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Sounds like you'll have to disassemble the door and fix , clean and lube everything up. You start by removing the wing window and all of the weatherstripping. That makes the side glass real loose in the door. Just work the window out and take the regulator assembly out and rework or replace it. Grease all of the rollers up and reassemble, Scott
If a regulator from a 63 C10 will fit, I have one if you need it. | | | | | Joined: Mar 2006 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 40 | Thanks for the light speed reply! Yes I would be interested in the regulator. From what I know the doors on the 60-63 pickups and trucks are the same? My regulator splines were all messed up when I bought the truck (vise grips). No inside handle either. This would be on the passenger side door. Let me know how much you need and what shipping would be.
Oh, do I need a special tool to get the screws out? They looked like a different type of head. Now for the stupid WD-40 can! | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Sorry I took so long getting back, computer problems. I can send you a regulator. E-mail me directly and we'll set things up. The "special" driver is a clutch-head driver. You can order them through most of these parts suppliers and some people have found them locally at hardware stores, parts houses and the like. Talk at you soon, Scott | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | use a stick magnet to get the can of WD-40  | | | | | Joined: Mar 2006 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 40 | Achipmunk,
Thanks for the good idea on the can removal. I will give it a try. | | |
