6 members (cmayna, Gdads51, 3B, moparguy, MickeyP, JW51), 110 guests, and 3 robots.
Topics128,064
Posts1,055,861
Members48,428
frown My window on my 62 C60 is stuck about 3/4 of the way down. I want to get it closed to keep the weather out. I tried to roll it up tonight and broke the short metal brace from the regulator to the main braces :o
I got the inner cover off and sprayed things with WD-40, you guessed it I dropped the can and I can't reach it frown Any ideas on how to solve these problems?
Sounds like you'll have to disassemble the door and fix , clean and lube everything up. You start by removing the wing window and all of the weatherstripping. That makes the side glass real loose in the door. Just work the window out and take the regulator assembly out and rework or replace it. Grease all of the rollers up and reassemble,
Scott
If a regulator from a 63 C10 will fit, I have one if you need it.
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks for the light speed reply! Yes I would be interested in the regulator. From what I know the doors on the 60-63 pickups and trucks are the same? My regulator splines were all messed up when I bought the truck (vise grips). No inside handle either. This would be on the passenger side door. Let me know how much you need and what shipping would be.
Oh, do I need a special tool to get the screws out? They looked like a different type of head. Now for the stupid WD-40 can!
Sorry I took so long getting back, computer problems.
I can send you a regulator. E-mail me directly and we'll set things up. The "special" driver is a clutch-head driver. You can order them through most of these parts suppliers and some people have found them locally at hardware stores, parts houses and the like.
Talk at you soon,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
use a stick magnet to get the can of WD-40 grin
Achipmunk,
Thanks for the good idea on the can removal. I will give it a try.
