5 members (Bill Hanlon, Joe H, Otto Skorzeny, Gdads51, 3B), 157 guests, and 4 robots.
Topics128,110
Posts1,056,246
Members48,437
#326042 06/13/2007 2:02 PM
Having made the bed- and anglestrips for my 53 3100 myself, I am now ready to make the wooden blocks/under bed spacers. However I cannot find the exact measures of those parts. Can anybody give me the answer? Thanks in advance!!
#326043 06/13/2007 2:36 PM
Do a search it has been covered a few times, the ones you see for sale are pine or alder but I have seen posts where people use oak. I bought a repo set and after reading some of the threads I am going to duplicate in oak.
#326044 06/13/2007 2:55 PM
you might also give a thought when replacing those to varnish them and add an XTRA rubber cushion to each of the 6 to help quiet the bed, more
Jim & Caroline
#326045 06/13/2007 5:13 PM
If you decide to use oak, use spar (marine) varnish - oak contains an acid that will promote rust unless you encapsulate it-- Good luck,
#326046 06/13/2007 5:57 PM
chevert: I am not sure but I think they are about 2 1/4 inches but don't take my word for it. I still have the ones from my panel I could measure but not sure it the panel/truck are the same. As CarolinesTruck mentioned but a little pad under them to reduce squeak etc. I have some old firehose that I cut up and it makes a real nice "pad" if you can get your hands on some. Its tough to. I'm sure someone will come a long with the right measurements and in the meantime I will measure my panel blocks just in case someone says they are the same. Good luck.
#326047 06/13/2007 6:20 PM
Whoever put the blocks under my bed made them high enough that a rubber spacer would make it sit a bit too high. I have no rubber on my blocks and there is no squeak. Not saying its right or wrong. Logic says rubber would help stop squeak.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#326048 06/13/2007 6:27 PM
I know this isn't original but could some of the new plastics be used instead of wood?
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
#326049 06/13/2007 7:00 PM
I'm pretty sure the blocks in the kit I bought were 2" tall and came with a pair of 1/8" rubber pads for top and bottom resulting in an overall height of 2 1/4". Aluminum or plastic are acceptable substitutes and correct height will be dependent on splash apron/bedside gap. The blocks wern't quite square either and had a longer side tha should run parallel to the framerail.
Curt B.
You Tube
#326050 06/14/2007 12:42 PM
Thanks all of you for answering and adding value to the answers as well! I will certainly make the blocks out of oak and there will be peices of rubber (with some woven material inside) on both sides of the blocks.
By the way; how informative and educational all those photo-albums are!!!
thanks again!
#326051 06/15/2007 2:32 PM
I measured the reproduction blocks I have at home and they are 2-1/4" square with a 3/8" hole through the center. The pads are the same 2-1/4" by 1/4" thick. I matched them up with the wood at Home Depot and they are alder.
