0 members (),
69
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 12 New Guy | | New Guy Joined: May 2006 Posts: 12 | Having made the bed- and anglestrips for my 53 3100 myself, I am now ready to make the wooden blocks/under bed spacers. However I cannot find the exact measures of those parts. Can anybody give me the answer? Thanks in advance!! | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Do a search it has been covered a few times, the ones you see for sale are pine or alder but I have seen posts where people use oak. I bought a repo set and after reading some of the threads I am going to duplicate in oak. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you might also give a thought when replacing those to varnish them and add an XTRA rubber cushion to each of the 6 to help quiet the bed, more
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | If you decide to use oak, use spar (marine) varnish - oak contains an acid that will promote rust unless you encapsulate it-- Good luck, | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | chevert: I am not sure but I think they are about 2 1/4 inches but don't take my word for it. I still have the ones from my panel I could measure but not sure it the panel/truck are the same. As CarolinesTruck mentioned but a little pad under them to reduce squeak etc. I have some old firehose that I cut up and it makes a real nice "pad" if you can get your hands on some. Its tough to. I'm sure someone will come a long with the right measurements and in the meantime I will measure my panel blocks just in case someone says they are the same. Good luck. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Whoever put the blocks under my bed made them high enough that a rubber spacer would make it sit a bit too high. I have no rubber on my blocks and there is no squeak. Not saying its right or wrong. Logic says rubber would help stop squeak. | | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | I know this isn't original but could some of the new plastics be used instead of wood?
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I'm pretty sure the blocks in the kit I bought were 2" tall and came with a pair of 1/8" rubber pads for top and bottom resulting in an overall height of 2 1/4". Aluminum or plastic are acceptable substitutes and correct height will be dependent on splash apron/bedside gap. The blocks wern't quite square either and had a longer side tha should run parallel to the framerail.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: May 2006 Posts: 12 New Guy | | New Guy Joined: May 2006 Posts: 12 | Thanks all of you for answering and adding value to the answers as well! I will certainly make the blocks out of oak and there will be peices of rubber (with some woven material inside) on both sides of the blocks. By the way; how informative and educational all those photo-albums are!!! thanks again! | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I measured the reproduction blocks I have at home and they are 2-1/4" square with a 3/8" hole through the center. The pads are the same 2-1/4" by 1/4" thick. I matched them up with the wood at Home Depot and they are alder. | | |
