3 members (Chip O, Charles in CA, 1 invisible),
159
Mod | | | Forums66 Topics128,087 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26641 03/18/2005 4:11 AM | | Anonymous Unregistered | | Anonymous Unregistered | I have read the article on the T-5 swap a few times because I am considering it for my 53. I have a few questions though, what did people use as a rearend? Also, I don't anything about clutches, so I don't really understand the astro disc or whatever it was... if some one could please clarify that, it would be great. Another question, my 60 has a 235 that I am also considering rebuilding and swaping it into my 53, would that be a better way to go? Would I have to do a tranny or gear swap on that anyways, or could I drive down the highway? Thanks lots. | | |
#26642 03/18/2005 5:33 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | If you do the swap, you will need an open rear, instead of the torque tube. The 235 would work well with the T5. If you swap engines, but keep your original tranny, the revs at speed won't change, so you may want to consider both swaps. As for the clutch, what you need is a clutch disk that will match your current flywheel/pressure plate combo (to keep the foot starter) and the right number of splines in the center to match the input shaft of the T5. There are links here which talk about different ones, or a custom clutch can be made.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#26643 03/18/2005 7:21 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | AC 53,
The rearends used vary from 80's full size truck rear, s-10 4X4 Automatic rearend (4x2 are too narrow), 70 to 81 Nova, Trans Am, Firebird, GM 10 or 12 bolt....as far as gear ratio desired, check the rpm/gear calculators on this site. When you go get a T-5, be sure to check the OD ratio. The one I have on the shelf is .86 or something like that. Mugsy on here put one in a world class with a ratio like .68 or similar. Put your tire size, tranny ratio and rearend ratio in the calc to figure out what RPM you will wind up with.
As for me, I will probably use the .86 I have and just mate it up to the right rearend to make it all work out with the 16 inch tires I am running. I am collecting the parts, but since my truck runs pretty well, I hate to take it apart. Going 55 MPH would be easier with the new setup tho... | | |
#26644 03/19/2005 3:58 AM | | Anonymous Unregistered | | Anonymous Unregistered | Thanks guys. Since my truck has a "rebuilt ( :rolleyes: )" 216 in it, I might aswell leave it as it is for now. If I come across a s10 tranny, how will I know what is a good one? by year? by serial number? or what? or (gasp) go to a V8, we have a old 85 chev (350/th400) farm truck that might become a donor. I dunno, but thanks for the replies!!!!! | | |
#26645 03/19/2005 4:54 AM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | AC,
If you do a google search on the T-5, you can find the tranny codes. The tranny should have a tag on it to tell you what OD ratio is has. KC Mongo on this site also has a list of the T-5 codes too. Surf his site when you find a post of his.
Heck..I'm with you. My 216 is still running..so no plans to ditch it either. I would like to do the T-5, but since I only have 5 miles to work, I don't feel the need to re-do my driveline yet. | | |
#26646 03/19/2005 5:43 AM | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Here you go Arcticat the list is here. http://www.mongosgarage.com/tech/t5/index.htm In my case, my 216 in my truck was a goner and I swapped in a 58 235 and converted to 12 volt. Then a few months later my 3 speed started slipping out of gear so I swapped to a later open rear end and the S10 5 speed, it has been the best improvement for driveability that I could have done. Mongo | | |
#26647 03/20/2005 2:43 AM | | Anonymous Unregistered | | Anonymous Unregistered | thanks guys for the replies. mongo, your article on the t-5 swap was good and cleared my mind a little on the swap. thanks | | |
#26649 03/21/2005 5:34 AM | | Anonymous Unregistered | | Anonymous Unregistered | thanks mugsy!!! i'll sort through that. I didn't sign up for your yahoo thing yet, but what does the "sleds" part stand for? | | |
#26650 03/21/2005 5:46 AM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | A sled is old slang for a car (primarily late 40's - mid 50's) that's filled with lead. Lead bodywork that is. Lead sled. Not too much lead being used these days so it's just plain old sled. -David | | |
#26651 03/22/2005 4:51 AM | | Anonymous Unregistered | | Anonymous Unregistered | Oh I see...I almost thought it was a snowmobile :p | | |
#26652 03/22/2005 6:36 PM | Joined: Mar 2005 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 85 | Hello all, I've visited this site many times over the last year or so but never registered 'til now. I do not own a "stovebolt" truck (although I would like to) however I do own a '57 Belair equipped with a "stovebolt" engine. I hope that meets any prerequisites that exist for this site.  (emoticon challenged) | | |
#26653 03/24/2005 11:04 PM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | Does anyone know what years of the T-5 have a mechanical speedo drive? Thanx Dano
69 C10 LWB 250 L-6/3spd 79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
#26654 03/26/2005 6:00 AM | Joined: Mar 2005 Posts: 9 Junior Member | | Junior Member Joined: Mar 2005 Posts: 9 | Thanks for the T-5 info guys. im doing one in my 63 c-10. Those links are really good. | | |
#26655 03/26/2005 6:05 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Hey BelairBolt Welcome, C'mon in, set a spell, etc. From what these more experienced gents here say, Stovebolt refers to the engine, not the vehicle. You'll see many here with cars as well as trucks. You Belair types are rare as most are swapped to V8's and frequent other boards. ANYONE with even a fondnes for the venerable straight-six is welcome here!
#26656 03/26/2005 6:39 PM | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Dano, This is an educated guess but, I think up to '91 had mechanical (or at least some were still mechanical). My tranny was sold to me as from a '91 IROC. I looked up the tag # online and it said '89 V8 WC. I then found some other info elsewhere which lead me to believe it was in fact from '91 and it is a mechanical speedo. -David | | |
#26657 03/30/2005 4:25 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | How does the T-5 transmission mount to the stock AD crossmember? I presume some modification is necessary. | | |
#26658 01/03/2006 5:48 AM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | anybody have a response to olblu49's last question? Thanks. | | |
#26659 01/03/2006 6:34 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I bought a universal trans crossmember for $45 but I believe you can just fab up a simple adapter plate to just relocate the holes. Need to make some kind of rubber mount too though. | | |
#26660 01/03/2006 11:27 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I believe 88 up in S-10,s are electronic speedo. I have a 90 & havn,t figured out what I,m going to put it in yet & what to do about the speedo. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#26661 01/04/2006 12:57 AM | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | In my case I just removed that crossmember, have had no trouple since, I had planned on putting it back and making an adapter plate for it but know a couple other guys running them this way without any trouble. MONGO | | |
#26662 01/04/2006 4:39 AM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | | | |
#26663 01/04/2006 9:34 PM | Joined: Dec 2005 Posts: 8 Junior Member | | Junior Member Joined: Dec 2005 Posts: 8 | I have also been looking to get better gearing and was considering a rear end or tranny swap. I have read quite a bit about this t-5 swap but most are on the 50s models. Is this swap do-able on a 66 c-10. I have the Muncie Hd 4-spd and a 4.11 rear Iwould like to make more hwy freindly. I have been to most of the links and threads, great stuff but haven't seen much w/c10s. Regards, Dennis | | |
